Question about Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 Had Paper Jam Now Will Not Load Paper.A Piece was Loose and I need to Know How To Thread It Back In Through The Cartridge.
Hi!
I had a paper jam and pulled the paper out of where it feeds into the printer. I opened the printer up to see if there was any leftover paper but instead found the actual printer cartridge going extremely slow and just acting funny.
Then I see this thin plastic strip loose on one side of the cartridge. It appears to have been threaded through the ink cartridge holder and somehow attached to the sides of the printer. (If that makes sense)
Anyway, without think I just pulled it out to inspect it and now I have no idea where it goes? I turned the printer back on and tried to print without it but it appears this strip of plastic acts to keep tension within the printer cartridge spool because everytime I pushed the ON/OFF button the cartridge would slam against the sides of the printer. (As with before it would stop itself automatically from hitting the side due to this strip.)
Anyway the strip is plastic tinted kind of like a car window except for the two holes on the side which are white and have a black arrow on both sides pointing ^ upwards.
If anyone can look and see where theirs goes that would be great! If anyone can help me please reply!! I really appreciate it!
Lexmark X2470
P.S. There is nothing about this in the user manual.
  • Anonymous Dec 14, 2008
    yea. i have the same problem.. a thin plastic strip fell out andnow the thng slams back and forth whenever its turned on.. nothing can print
Installation
Posted on Sep 28, 2008
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
I have a lexmark x2470 printer.i would like to know whether it as one cartidge or two cartridges.please let me know if it is available in indaia
HI,
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor."
2. Click on "File" and then "Open" to select the color image file.
3. Click on "Image," "Mode" and then select "Grayscale."
4. Click on "Print."
This will print the image in gray.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
I have a lexmark 5470 there is paper jammed and I cannot get to the jam It is a all in one printer
alternative :
Jun 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2470 (aka piece of junk)
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 22, 2009 | Lexmark X2470 All-In-One InkJet Printer
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
alternative :
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Paper jam. When I use my printer paper is jam and goes at a wrong angle. Please. Let me know how I can fix of it. Thanks. Valeriy
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
alternative :
Lexmark paper stuck
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck....
Jul 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
