Question about Maytag Neptune MDE5500AY Electric Dryer
No power after door is shut
I have power and the panel lights,door light etc. are on.When I shut the door all lights go out, and dryer dosen't work.Is this a problem with the switch inside the door?All three wires have been checked for power, all OK. What is an intermittent type ignition device?Could it be that? Thanks.
  • Maytag Master
  • 19,396 Answers
Check all fuses and circuit breakers , test with a multimeter the door switch, ensure it is working, if this parts are fine, then the problem is with the control timer. In that case you will need to replace it.
See also the following website: What is wrong with your Dryer?
You can get replacements here, also insert model number to get schematics.
Posted on Oct 15, 2008
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
Nov 21, 2017 | Whirlpool Dryers
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
No power to panel or inside light will not turn on.
check the door switch if they go completely bad it will kill everything..... door open or closed
Feb 11, 2012 | Dryers
Kenmore dryer doesnt have power there is continuity to the timer and the switch
Is there power at the receptacle? The easy way to check this is to go to your electrical panel, turn off the 30 amp (2 - pole) circuit breaker, wait a few seconds and then turn it back on. If you have any lights, digital displays, etc. that indicate power being on to the dryer - then try going through your routine again for drying your clothes. If this doesn't do it, feel free to contact me again - and I'll help you with the next step. Sometimes the door latch can affect power. Meaning, if the door isn't shut all the way - it won't turn on. Now, if it is shut all the way and you know you have power to the machine, and it still won't work. A faulty door latch switch has been known to be the cause. Good Luck to you, and I hope the simple solution works for you. - Jim
Mar 29, 2010 | Kenmore 62882 Electric Dryer
My neptune dryer does not work no power light on panel.does not turn on
Check fuse and 13 amp socket etc..All ok ! check supply lead and door is closed .
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not work, has electrical power, but does not light up
look for a fuse mounted beside the heater element. small black with 2 white wires attached, open and the dryer don work, but wait thers more... look into the blower assembly for blockage of lint or loose blower.
Jan 30, 2009 | Maytag MDE9700AYM Electric Dryer
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Oct 08, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
