Question about Hoover Washing Machines
Hoover VHd964ZD washer: door refusing to open after cycles finished for the fourth time. Previous repairs included catch adjustments and extra packing to catch hook - to no avail.
  • 641 Answers
SOURCE: Washer won't fast spin or drain
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Posted on Sep 04, 2007
SOURCE: hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Posted on Jul 02, 2008
  • 3463 Answers
SOURCE: hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Plz rate my solution
Posted on Jan 23, 2009
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Posted on Feb 18, 2010
SOURCE: Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Posted on Sep 06, 2010
Hoover HFOE54B fridge ice box door catch does not close properly.
The door needs adjusting as the seal is usually magnetic.
Jul 16, 2017 | Hoover Refrigerators
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle
yes it can be replaced, take photo and model number of machine
order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
Oct 05, 2016 | Hoover AAA160 Front Load Washer
Door locking
the door mechanisum is proberly worn and the catch its best to replace both
Dec 05, 2011 | Hoover H120M Front Load Washer / Dryer
My Hoover 750 washing machine does not spin any more. What would cause that and can I fix it with a new part?
The answer to your question is YES.
And below is the instruction on how to solve the problem.
The Hoover750 is a washing machine that offers many standard features and a few additional options, including energy saving cycles, variable spin and water pressure options and pre-wash, extra rinse and timer features. Available online and in select appliance, department or home retail stores, the Hoover washing machine should function well with basic maintenance and care. However, if individuals experience problems with the machine, some troubleshooting steps may be beneficial in locating the source of the issue and a potential resolution.
1. Ensure the Hoover washing machine is firmly connected to a grounded power supply if the machine is not working. Reset the circuit breaker if necessary.
2 Turn the main power switch to "On" and open and close the washer door firmly if the electrical outlet has power but the washer is not functioning. The washer will not operate if not turned on or if the door is open.
3 Verify the water inlet hoses are connected firmly and are turned on if there is no water flowing to the washing machine. Straighten out any kinks in the hoses and remove possible obstructions from the inlet screen.
4 Straighten the drain hose if the water is not draining from the unit. Remove any possible blockages from the drain hose. Tighten the hose if necessary.
5 Avoid selecting a "No Spin" option if the washer is not spinning water out of the drum. Choose a new spin cycle and press "Start" to remove water from the drum.
6 Verify that all four feet are touching the ground evenly if the washing machine is rocking or vibrating during use. Adjust as needed.
Feb 19, 2011 | Hoover Washing Machines
The door on my hoover nextra washer drier sometimes does not open and I have to put the machine on a further cycle and then wait for the door release mechanism ot click and then open the door quickly
the clthes may be getting a false sensor reading that there still damp it may be vey humid,after a load of clothes try running some bleach through only put on heavy duty wash and extra rinse,the machine my have residue from softener. so sanitize machine a few times.
Jul 21, 2010 | Washing Machines
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Door wont open on my washing machine hoover select 1500
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hoover Washing M/C Door Jammed
we had the same problem on ours, a techy came out to it and hit the washer above and the the right of the door handle, and hey presto the door opened, have done this myself since, works everytime
Nov 03, 2008 | Hoover AAA160 Front Load Washer
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Washing Machines Logo
67 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
