Question about Whirlpool Washing Machines
My washing machine works most of the time but sometimes i need to push the door really hard a few times to get the cycle to start. Today it broke down half way through cycle, got it going again then the dryer bit broke and now it wont switch onn
  • 550 Answers
Hi
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
Posted on Sep 21, 2008
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
My door will not open on my washer and it will not start the wash
try pulling the handle with youre left hand kind of hard & at same time push in on door with right hand close to handle work it back & forth if that don't work try jerking on handle with left hand with right one on machine gasket maybe stuck or handle broke inside door hope u luck Nick
Feb 12, 2015 | Washing Machines
A have a swan washing machine its a sw2020s a went to put machine on but 3 lights start flashingnext to the on button av just had it serviced before the guarantee ran out now a dont no what to do plz help...
Most wasing machine problems are with door contact and sometimes drain hose. If door contact try to push a screw driver to push the door contact or lock a few times.. check drain hose position with your installation manual. Since u have used it for some time prob it is the first problem..
Jan 26, 2015 | Washing Machines
I have a Sears Kenmore elite model #10045081400, I have an intermittent problem. Sometimes it works fine and other times after I load the washer set the cycle and press the start button, it just clicks...
suggest you call a repair service tho intermittent problems are really hard to pin down.might just be the door switch needs some adjustment and or a screw tightened
Sep 18, 2017 | Washing Machines
Have to really push door ******* washing machine to get it starting its cycle
Your washing machine door lock are broken :(. Change it with new one and forgot all problems.
Apr 13, 2013 | Washing Machines
Washing machine will not start
It is your central control unit...........try ing hitting the top with hand toward the back of machine sometimes there is a short in the CCU and a little shake will correct
Apr 06, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
