52" rca scenium HDTV around 5 years old problem: the tv was working fine. then the next day i turned it on and it only had sound and no picture. now it don't even turn on at all no sound or picture. the little led light on the power button flashed and some times when you try to turn it on it makes a vary faint but loud enough to hear wisthle like its powering down. the wistle only lasts about 3-5 seconds and it fades out
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
  • 1030 Answers
SOURCE: RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Posted on Feb 29, 2008
SOURCE: RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Posted on Apr 05, 2008
SOURCE: power light flashes 3 times
U CAN THRO THE ******* THING BACK AT THE ******* PEOPLE WHO MADE IT!!!!!!!!!1 I GOT THE SAME ******* PROUBLEM AS THE OTHER GUYZ!!!! BUYING A **** N SONY NEVER AGIAN A RCA ********!!!
Posted on May 23, 2008
Slapnuts1975
  • 51 Answers
SOURCE: "52" RCA Scenium DLP; No Picture and the buttons flash on and off
On the back of the TV, you'll find the Access door to your lamp. Unplug the TV from power, and remove the screw on the access panel. Inside you'll find 2 additional screws holding in the lamp housing assembly. Remove the screws, then the lamp assembly and visibly inpect it. You'll know if the lamp is defective, it will have obvious damage. If so replace with part # 260962, you can acquire this lamp for arround 100 dollars off ebay, or 262.00 direct from RCA.
Posted on Jun 04, 2008
We have a 14 year old rca scenium that the picture looks like a paint by number,what can i do to fix this? thanks
If your RCA TV is 14 years old, it may be nearing end of life. You may find repair is not worth considering.
Sep 10, 2014 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
RCA Scenium HTV won't turn on
My tv is about not even 3 years old, the bulb was already replaced once and now the tv will not turn on, we replaced the bulb again, but no change... The blue lights come on and flash but eventually turn off.
Jul 14, 2008 | RCA Scenium M50WH187 50" HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Question
have convergence rebuilt........
Jun 01, 2008 | RCA HD52W56 52" Rear Projection HDTV
52"RCA Rear Proj. TVs turn off and on then not at all
did u have a lightning storm or a power surge. sounds like too much of a coincedince for both to go down with out a spike in the electrical supply.
Jan 05, 2008 | RCA Scenium D40W20 40" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
