Question about Dishwashers
AEG 50862 error code 30
What is cousing this. and how can I fx this regards Joh.
  • Anonymous Apr 04, 2009
    error 30.
4 Suggested Answers
SOURCE: how do i fix error code 30?
I did like it was suggested and it functioned! Can't believe it. Actually I tipped the machine over, but not till the end (very slightly). It was a bit water on the ground. I removed it and put the machine upright. Thanks a lot!
Posted on Dec 31, 2007
  • 54 Answers
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Posted on Feb 14, 2008
SOURCE: error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Posted on Mar 28, 2008
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
AEG F65070VI fitted dishwasher error code 46 & 30
This error is flood alert because of a leak in the tub. IT might be a seal but you have to remove it and drain it and lay it down to see and then you need parts.
Jun 04, 2013 | AEG Dishwashers
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Error code 30
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
Feb 14, 2008 | Dishwashers
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
