Computers & Internet Logo
Anonymous Posted on Oct 10, 2011
Http://drmlicense.one.microsoft.com/ - Netscape Communicator
1helpful
The medial Player give the message error cood11B1
Try this.download the patch from
.http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp
Make sure you use IE
Hope this helps.
Regards Bill
I can not get overdrive to doen load audio books from the libary, it says ''error 0xC00D2751 a problem has occured in the digital rights management component contact microsoft product support. I went to...
Try resetting the DRM (Digital Rights Management) for Windows Media Player. 1. Open the 'Control Panel'.
2. Open 'Folder Options' and select the 'View' tab.
3. Select 'Show hidden files and folders'.
4. Uncheck 'Hide protected operating system files'.
5. In the warning message you receive, click 'Yes'.
6. Click 'OK'.
7. Close the Control Panel
8. Rename the DRM folder to DRM.old.
-C:\Documents and Settings\All Users\ DRM
9. Close this window and open OverDrive Media Console.
10. Go to “Tools > Windows Media Player Security Upgrade”.
If it will not run from the OverDrive Media Console, the security
upgrade may also be run by going to (in Internet Explorer only) the
following site: http://drmlicense.one.microsoft.com/Indivsite
11. Download an OverDrive Audiobook.
1helpful
2answers
1helpful
2answers
Encountered error message C00D11B1 while using Windows Media Player
There are different solutions on your problem here I did find some of them:
Try to use ccleaner and be sure that windows media player is checked :
http://www.ccleaner.com/
1: try to download this codek pack and install it :
http://www.free-codecs.com/download/XP_Codec_Pack.htm
2: it is related to updates your error you have to do this :
3: try to remove all the files from this folder- C:\Documents and Settings\All Users\DRM\- to a new subfolder and try this :
moving ALL the files in the folder: C:\ProgramData\Microsoft\Windows\DRM\ as well as the files in the “Cache” folder beneath that was the magic trick. I don’t know if you need to move from both folders, . Note that media player had to re-download the licenses. If it not work you can always return them from the folder back.
For more solutions please see here from the source link :
http://strom.wordpress.com/2007/04/06/windows-media-player-error-c00d11b1-solved/
Hope that helps
IF NOT then return here
Please rate my answer
Other support places :
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/default.aspx
DRM components wont install
Open the following link and click on up[grade button:
http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp?force=1
Or download the following file and execute on the computer:
http://www.napster.com/client/drmreset/DRM_reset.exe
I have been trying to download the drivers for Lexmark printer Z53 for a week. I've tried several times on two different computers and keep getting error "message 1603 error installing Microsofft.net...
Windows Update error code "0x643" and Windows Installer error code "1603" are generic error codes. Typically, these error codes mean that the update was not installed. These errors codes are usually caused by a corruption in the .NET Framework installation or by an inconsistency on the MSI database state.
Method 1: Manually remove and reinstall .NET Framework loadTOCNode(2, 'resolution'); To manually remove and reinstall the .NET Framework, follow these steps:
  1. Remove the .NET Framework.
    1. Click Start, and then click Control Panel.
    2. Double-click Add or Remove Programs.
    3. Note each version of the .NET Framework that is already installed on the computer. Then, uninstall all the versions of the .NET Framework.
    4. When you are prompted, restart the computer.
  2. Use the Windows Installer CleanUp Utility to clean up the MSI database state for all the versions of the .NET Framework.
    1. Download the Windows Installer CleanUp Utility. The following file is available for download from the Microsoft Download Center:
      Download the Windows Installer CleanUp Utility package now. (http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe)
      For more information about how to download Microsoft support files, click the following article number to view the article in the Microsoft Knowledge Base: 119591 (http://support.microsoft.com/kb/119591/ ) How to obtain Microsoft support files from online services Microsoft scanned this file for viruses. Microsoft used the most current virus-detection software that was available on the date that the file was posted. The file is stored on security-enhanced servers that help prevent any unauthorized changes to the file.
    2. Install the Windows Installer CleanUp Utility as an administrator or as a user account that is a member of the local Administrators group.
    3. Click Start, point to All Programs, and then click Windows Install Cleanup.
    4. In the Windows Installer CleanUp Utility, remove all Windows Installer applications for the .NET Framework.
  3. Restart the computer.
  4. Download and then reinstall all the versions of the .NET Framework that were previously installed on the computer.
    To download the .NET Framework 1.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en) To download the .NET Framework 1.0 Service Pack 3, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en) To download the .NET Framework 1.1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en) To download the .NET Framework 1.1 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en) To download the .NET Framework 2.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en) To download the .NET Framework 2.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en) To download the .NET Framework 3.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en) To download the .NET Framework 3.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en) To download the .NET Framework 3.5, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en)
  5. When you are prompted, restart the computer.
Note When you have reinstalled all the versions of the .NET Framework, you can use Windows Update to check for updates to the .NET Framework.
2answers
Why is my sound heard only at the ear piece lately?
Try this patch. http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp
2answers
Am totally mad please help me out
try formatting your computer
and load your drivers properly
1helpful
Rhapsody Issues
Format the device completely and then do a DRM reset on your computer...
To do a DRM reset..Assuming that you have windows xp..
Click on your start menu on your computer, click on my computer..Click on tools, folder options, click on view, click on show hidden files and folders then uncheck the box for hide protected operating system..its going to give you a warning just disregard it..click on your C drive, documents and settings, all users and there should be a DRM folder there,,you want to delete the content of the DRm folder..not the folder itself...then restart your computer...follow the link below after that to upgrade your security component....
Then you should be all good to go
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Cannot get the damn thing to work...
You will need to update your DRM (Digital Rights Management) components from Microsoft.
Best of Luck.
Top Netscape Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netscape Computer and Internet Expert? Answer questions, earn points and help others
