Hoover hnf 6167 noise when spinning and one of the drum tumbler things keeps breaking off
  • 550 Answers
The screws that hold the baffle on have worked loose and are rattling around in the outer drum. causing both nopise and baffle falling about.
Posted on Sep 21, 2008
  • AlmostBob
    AlmostBob Sep 22, 2008
    Dunno how to fix this particular machine,
    for most it is pretty simple once you work out how to open the case
Why is the drum not spinning on my Hoover VisionTech VTS712D21 Washing Machine?
It could be the drum bearings are seizing or something is causing it to jam.
If this is the case the motor would work too hard and draw too much current and consequently would cut out for a time and then reset.
Removing the drivebelt and turning the drum by hand would show if this is probable.
Feb 20, 2017 | Hoover Washing Machines
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Grinding noise when drum spins
they r hard rubber attachments that keep the tumbler from grinding metal to metal. go to local appliance center 15bucks a set. easy fix
Mar 17, 2013 | Maytag ADE7005AYW Dryer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine
Here is what I suggested to another person with a similar request......
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or break motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty. When you close the lid again, you will hear the solenoid release the drum, and then the motor starts spinning the drum again.
If that is the case, it is normal and no need to worry about it. However, if you did not have the noise before, then best to get a repairer to check it out.
Regards
Ash
Nov 08, 2009 | Washing Machines
Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Jul 26, 2008 | Hoover Washing Machines
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
