Question about Honeywell Heating & Cooling
My thermostat keeps saying BAE Lo - Honeywell Heating & Cooling
I just looked up this issue tonight. The batteries in my thermostat needed to be replaced, so I replaced them with two new double AA batteries and now all is well.
Posted on Nov 18, 2008
    Problem Solver:
  • 5 Answers
Sounds like you have a low battery. go online or find your owners manual and look up your code.
Posted on Sep 22, 2008
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: bae lo This is the message
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Posted on Dec 13, 2010
  • 472 Answers
SOURCE: My thermostat is flashing bAE
i think this is a sign your batteries in thermost need replaced .... the lcd may be damaged but try removing the cover and replace the batteries in unit...if there is a reset button behind the cover after you have replaced your batteries hold the reset for about 5 seconds and see what happens/.... if that doesnt work remove the red wire on thermostat and the wire that is hooked to the c terminal; if you have one for about 10 seconds and reconnect... do not touch wires together this is only a 24 volt circuit but if the wires are shorted can cause more problem so be careful...as long as your not wet or sweating you want fill the small amount of voltage but if so may tingle trust me it will not hurt you 24 volts .... give that a try the batteries first though good luck to you
Posted on Jan 06, 2011
Hunter 44860 touchscreen thermostat- My thermostat displays "LO". My wife said she played with it and can't fix it. He heat won't shut off! I thought it was the batteries so I replaced them. I noticed...
I suggest to everyone NEVER to buy a cheap thermostat from any box store regardless of brand. Always go with Honeywell or White Rodgers high end stats and DO NOT lose their booklets.
Feb 19, 2015 | Heating & Cooling
My thermostat is flashing bAE Lo.... and I can't view temp - what does this mean?
Jan 06, 2011 | Heating & Cooling
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Dec 12, 2010 | Heating & Cooling
I replaced the batteries, but it still says lo batt. the batteries are new
in some thermostats it is required that you have a common lead hooked to Thermostat and back too the transformer in the air handler unit the batteries are used as a back up in the event the power goes out too keep your program in thermostat. if the common lead is not attached your thermostat is being powered by the batteries only and not the system control power, and will drain batteries fast.
Sep 06, 2010 | Honeywell Programmable Thermostat Heater
I can not set up the bluetooth bae-829d with my
i have a sidekick, and it saying it connected but it wont let me answer calls or anything
Oct 15, 2009 | Plantronics - Bluetooth Headset Plus Base...
My york central air condenser keeps running. It cools but, it just keeps running.
Some possible problems..turn thermostat where AC compressor should not run. measure lo voltage to the contactor in the compressor housing. If there is voltage there then thermostat is defective. Remove one lead of lo voltage at contactor. Compresor should stop. If not contacts are stuck. Replace or burnish contacts..
Apr 27, 2009 | Samsung AW0503B Air Conditioner
Heating & Cooling Logo
4,740 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
