Question about Video Game Consoles & Games
Theres a 3 red light appearing in my x-box console, what will i do?
  • 4 Answers
Call 1-800-4myxbox to explain your problem and they will most likely be able to fix it for free...(it a microsoft customer service number) and the problem is do to hardware malfunction.
Posted on Sep 21, 2008
2 RED LIGHTS ON XBOX 360
Two red lights sometimes means power to console troubles. There is a code you can get from machine and this can direct you better to cause of failure. When the machine is on press the sync button then the eject button at the same time. The 2 red lights will go and lights will appear and this will be youre first digit of the 4 digit code. Do this 4 times. 1 red light is 1. 2 is 2. 3 is 3. 4 red lights is 0. Let us know the code and i may be able to put you in the right direction.
Jul 01, 2010 | Microsoft Xbox 360 Console
Tip
How To Permanently Fix The Red Light Problem On Your PS3 Today!
The Red Light problem on the PlayStation 3 appears to be a wide spread issue affecting countless PlayStation 3 users. Many users are puzzled as to why this problem struck them; many are dedicated Sony users and didn't believe their PlayStation 3 could be struck down with the PlayStation 3 Red Light problem. It is hard to say what causes the PlayStation 3 Red Light, however we can provide you with some tips that could get rid of the Red Light problem:
  1. Check if there's a loose cable. If not, restart your console.
  2. Unplug all cables except the power cord, and plug them back in.
  3. If that didn't work, then try to take out the hard-drive, and put it back in.
Learn how to fix your PlayStation 3 today with the PlayStation 3 Repair Program, designed to help PlayStation 3 users effectively banish the PlayStation 3 Red Light problem today!
Source: Best Yellow Light of Death Fixing Kit
on Oct 01, 2013 | Sony Playstation 3 (PS3) Console
3 red lights box under 3 years old
RED LIGHT OF DEATH!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 motherboard or power supply.You can test power supply with a voltmeter from power supply wires to the connections on the motherboard. If no power or low power, the supply is bad. If there is plenty of power, then motherboard could have bad capacitor or chipset on it causing the problems. You can test those with an ohmmeter to see which component is not the same.
Nov 23, 2009 | Microsoft Xbox 360 Console
Red lights appear on consule what do i do
gavphilipson
To clarify are you getting 4 red lights or 3 red lights
If it is 4 light then this is just a system error that you video is not connected right. If you have you AV and/or HDMI cable connected to the XBOX then most like you have a bad cable. If you have tried another cable then most likely then there is something wrong with the video connector on the system.
If it is 3 light then you have the "red ring of death" issue. This is a general hardware error. If you go through the red ring repair steps this would fix the issue.
Hope this helps
Issken
Nov 07, 2009 | Microsoft Xbox 360 Console
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
after turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Jul 17, 2009 | Microsoft Xbox 360 Console
What is the problem when red light is appear?
the other tech is correct but theres also other causes. if 4 red lights are flashing making a full ring your av plug at the back of the xbox is not plugged in. if it has 2 red flashing lights yor unit is overheating. 3 red flashing lights means your cpu is unstuck and is stuffed. 1 red flashing light is a HDD issue
Jun 16, 2009 | Microsoft Xbox 360 Console
3 red lights appear - XBOX
Your console is most likely in need of repair.
The 3 Red Lights (known as the red ring of death) is caused when the unit overheats, and burns out some integral parts on the motherboard.
Call Microsoft, if your Xbox is less than 3 years old, they'll set you up with an exchange. It'll take 4 weeks, and you'll have to pay for shipping your broken Xbox, but it'll get fixed.
As far as I know, there's no way to permanently repair the Red ring of death yourself.
Apr 10, 2009 | Microsoft Xbox 360 Elite Console
When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply is button is red than you need to replace the battery or check the connections.
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. If you are experiencing this problem, you can submit a console-repair request online.
Hopefully your system is still under warranty.
For step by step troubleshooting directions please read the attached link and Happy Gaming!
http://support.microsoft.com/kb/907534
Oct 17, 2008 | Microsoft Xbox 360 Console
Dealing with X box
just click this;
Great news everyone - FixyaExpert found the solution for the xbox 360 3 red lights problem.
Click here for more info.
hope this may help,
DON'T FORGET TO RATE:
Regards,
VOTIT
Jul 30, 2008 | Microsoft Xbox 360 Console
How to make 3 red lights xbox360
easy just put something that covers the fans in the back and turn the xbox on and never turn it off and the red lights of death will appear.
Jul 10, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
