I have a similar problem with my 2005 Optra 5 - daytime running lights are hit/miss. About 3-4 years ago, the alarm started activating itself - FREQUENTLY. Turns out it was corroded wires. Now this. (Take heart - my Corolla had a similar problem - bad sockets - bulbs burned out faster than they could be replaced. Toyota never did admit responsibility.)
Road Safety Recalls Database
Print this Page
Transport Canada Recall # 2007315
Recall Date:
2007/09/28
Notification Type:
Safety Mfr
System:
Lights And Instruments
Manufacturer Recall Number:
07240
Units Affected:
33,865
Category:
Car
Recall Details:
Certain vehicles may experience a loss of headlamp low beam or Daytime Running Light (DRL) function as a result of a melted instrument panel harness connector. Low beam failure would lead to reduced visibility during hours of darkness. DRL failure may render the vehicle less visible to other motorists and pedestrians during daylight hours. Both cases could lead to a vehicle crash with injury or death. Correction: Dealers will add a direct connection splice clip to the headlamp low beam circuit in order to bypass the faulty connector.
Make
Model
Model Year(s) Affected
CHEVROLET
OPTRA
2004 2005 2006
I have repaired this problem on another optra befor you need to take the drivers front wheel well cover out and look for corroded wires or green death the one battery positive wire will be cut and or correded hope this helps
My optra did the same thing it is a recall on the car so just call your local dealership and they will fix it for you.
I have the same problem,driving lights works but not the low and hi beams,fuses and bulbs change.hold the switch the other way and keep it in and the high beams works.
