Question about Franke Saphira Espresso & Coffee Maker
Franke saphira bean to cup
The milk will not **** up ? Has the pump gone? Thanks Scott
  • 4,472 Answers
How long have you owned the unit? That is very possible that or the control/button for it is bad.
Once I have more information I can assist you further.
Thanks,
Lee
Posted on Sep 22, 2008
I've got a Franke Saphira no steam & no hot water ? It was steaming very slowly then heared a pop as if I pipe had burst ?.
the outlet was probably blocked by old milk. inside the metal tube there is a flexible hose. that is either broke or it came loose on the electrical valve.
Jan 02, 2016 | Franke Coffee Makers & Espresso Machines
How do I check the milk brother valve on my coffee machine
saphira? check the air nozzle on top of the cappu-outlet . if the machine indicates that you should descale, the cleaning cyclus wont work. to descale you have to turn off the machine by pressing the on-off button on the front side (behind the tea-and steam button). if the machine is turned off, press the descale button for 3 seconds. after the descaling cyclus you will be able to clean the machine.
Nov 05, 2014 | Franke Saphira Espresso & Coffee Maker
Machine grinds beans but dumps coffee in box cup
hi , sounds like the dump valve solenoid has failed or the valve on the base of the brewer has failed probably stuck,.which is the more likely culprit. let me know if you require more in depth help.
its not a problem that can be resolved by a novice.
Mar 30, 2014 | Franke Saphira Espresso & Coffee Maker
My frankie flair grinds the beans but the water just goes straight to the drip tray why
this problem is usual caused by the valve at the base of the brew unit. not working correctly or the solenoid which controls it. usually a replacement brew unit can resolve this.
Dec 17, 2013 | Franke Saphira Espresso & Coffee Maker
Franke Saphira malfunktion 2
You might find the answer on our Franke video
More info at Denby Dale Coffee
Nov 21, 2012 | Franke Saphira Espresso & Coffee Maker
Need a parts brake down diagram for a franke saphira coffee machine!!!
The Franke Saphira is the same machine as the Jura X7.
Here is an interactive diagram.
Mar 04, 2011 | Franke Saphira Espresso & Coffee Maker
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Can I use Jura cleaning tablets on franke saphira?
hi , you can use the cleaning tablets as jura and franke have the same brewing unit,
Sep 16, 2010 | Franke Saphira Espresso & Coffee Maker
Franke saphira will not exit rinse unit, will not rinse the coffee head but will supply hot water and steam. but will not depense any coffee. help please. I have had a Franke Man out and he has no clue he...
The machine has two pumps - one for each boiler. Did the Franke man check both pumps were working. If the main boiler pump has failed, the machine will know that the rinse hasn't occurred and won't go any further.
Feb 16, 2010 | Franke Saphira Espresso & Coffee Maker
Franke Saphira Espresso & Coffee Maker Logo
158 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
