Question about Motorola Mobility RAZR V3
V9m Powers off
I replaced my v3c for a v9m and that is the biggest mistake i ever made. for starters when i clap my hands with the phone in between it powers off and in order to start it again i have to take out the battery and put it back and press power then it starts. My v3c i was able to trow and nothing happend to it, what a screw up. I have a heck of a problem getting the charger on without damaging the plastic cover on the port. them things need to be stuffed up there nose. You would think if you buy a 600 dollar phone it should be worth somehting. what in the world they find so expensive on it only they would know. then top it all off they say it's your problem when u complain about it. The battery life sucks and that touch screen on the front, i have to press the butten 5 times before it opens the message. I thought it was suposed to be a good phone. 5 talking hours on it and already ginving trouble.
    Brigadier General:
  • 7,752 Answers
If the phone is still under-warranty you will need to take the phone back and have it replaced if not then you need to have it fix.
Posted on Sep 24, 2008
Subsidy code required for v9m
You can get the Unlock code(Subsidy code) for Motorola Razr V9M model Phone at
Mobile-unlocker.com/motorola/rs2wp8/ and unlock it easily.
Aug 22, 2012 | Cell Phones
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
Verizon V9M bluetooth cell phone does not fully work with car
I have the same problem and thus far my research shows that the V9M is NOT a supported phone on the 2010 E class. You can store manually numbers into the car's system.
Aug 23, 2009 | Cell Phones
I Cannot connect to Phone Tools via USB with Motorazr2 V9m?!?!?!?
I have the same problem as your's mine is also not listed on the List. What I did the first time I configured my MOTORAZR2 V9 is Open the main menu (I hope you do the same) >Select CONNECTION> CHOOSE between BLUETOOTH LINK or USB SETTINGS> In Bluetooth > Select SETUP>SELECT POWER ON. Now you have tour BLUETOOTH ON. USB SETTINGS is more easier all you need is USB TRANSFER DATA CABLE (as I understands it comes with your hand phone as in mine)
Feb 24, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Unlock code
It is usually the last 4 digits of your cell phone number.
Jan 18, 2009 | Verizon Communications Motorola MOTORAZR2...
Motorola MOTORAZR² V9m
Go to Menu/settings/initial setup/master reset enter 6 zero ok.
Similar Menu/setting/initial setup/master clear enter 6 zero ok.
Before to do that function,copy all phone book to simcard.
Dec 26, 2008 | Verizon Communications Motorola MOTORAZR2...
I need help uploading music on the razr2 V9m.
i want know that whether you mobile detected by computer or not if not please insert driver again
Dec 23, 2008 | Motorola Mobility RAZR V3
Locked razr 2 v9m
the default code is 000000 - security and the unlock default is 1234....you do not need to reflash the phone take the phone to a mobile service center and have them reset it for you.
Feb 23, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
