Question about Pioneer DEH-P850MP CD Player
PIONEER PREMIER DEH-P850MP
CANNOT ACCESS REAR FACE PLATE WHEN I PUSH THE OPEN BUTTON FRT FACE PLATE OPENS AND CLOSES OVER AND OVER UNTIL I PRESS RESET. IT OPENS TO THE POSITION THAT IT OPENS TO WHEN LOADING OR EJECTING A CD BUT CLOSES RIGHT BACK. MY MAIN ISSUE IS NOT BEING ABLE TO FINE TUNE AUDIO OR CLOCK. ALL AUDIO CONTROLS ARE ON REAR FACE PLATE.
  • 84hutch Jan 11, 2009
    when i press the open button it folds half way down then turns off and goes back up and it just keeps doing it over and over till i reset it.
  • Anonymous May 11, 2010
    When it opens, does it turn off, and then close, then turns on and opens, and then repeats?
    If that that is the case, then the same as: http://www.fixya.com/support/t1759729-no...
    "Its the ribbon cable which connects the faceplate to the main unit.
    Thebad thing about these types of receivers, is after a lot of flip downsand flip up, the wires in the ribbon cable get weak and break.
    If you want to fix it yourself:
    http://shop.ebay.com/items/_W0QQ_nkwZDEH...
    I had this same problem, and was able to fix it myself.
    Best of luck!!"
jbreth
  • 69 Answers
SOURCE: Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Posted on Sep 04, 2007
mixmaster
  • 626 Answers
SOURCE: pioneer deh-p850mp problem
Check the ribbon cable on the inside that connects the two parts.
You will need to remove the faceplate and open up the Rear of the unit.
If you bought it used, theres a good chance that the ribbon is in fact broken. If its new, check the connections on the ribbon cable.
It is a chronic problem with most all PIONEER units that fold down / out.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 22, 2007
SOURCE: Pioneer DEH-9600: No power to rear screen
bad ribbon cable
Posted on Mar 25, 2008
there is a broken ribbon cable that needs to be replaced. parts and labor shouldnt cost you more than a 100 bucks. worth it since it never has the problem again
Posted on Apr 10, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
Faceplate won't open all the way
Sometimes the mechanism is misplaced, just disassemble that mechanism and turn on radio without the secondary plate and wait until the motor to get to the final position when it turns off again, reassemble.
Oct 06, 2012 | Pioneer Premier DEH-P960MP CD Player
Pioneer premier deh-p880 prs faceplate opens when you turn car off
The face folds down to give you the option to remove the face if you want. It will return to the upright position a few seconds later whether you remove the face or not. There should be a tab on the underside of the face you can push should you decide to detach the face from the chassis.
May 07, 2012 | Pioneer Premier DEH-P880PRS
Pioneer Premier DHH-P930 cd stuck, how to eject?
The eject button is on the lower right hand corner. The button should say open. It opens the face plate
Jan 31, 2009 | Pioneer DEH-P930 CD Player
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Unit opens and closes on its own
I think I got the second half of the solution for this problem. Please look at post "Unit powers down when motorized face opens" for a solution. Seems like we need to buy the ribbon that connects to the face plate to fix this problem.
Jan 21, 2008 | Pioneer DEH-P8500MP CD Player
Faceplate won't go to up position
The flexible pcb that connects the front to the main board needs replacing, common fault
Dec 11, 2007 | Pioneer Premier DEH-P960MP CD Player
Pioneer deh-p850mp problem
Best of Luck.
Nov 22, 2007 | Pioneer DEH-P850MP CD Player
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
Apr 11, 2007 | Pioneer DEH-P8500MP CD Player
Pioneer DEH-P850MP CD Player Logo
181 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
