Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Our Oven seems to be stuck in the Self-cleaning mode
Every time I try to turn it on it goes automatically to self clean mode. I can't use the oven at all because of it. It won't allow me to shut it off. I ran it through the clean cycle the first time it happened. But it has never stopped since. Any suggestions?
  • 1 more comment
  • chowbaby6792 Sep 21, 2008
    Yes we tried that but no success...any other suggestions? Thanks
  • chowbaby6792 Sep 25, 2008
    The door is unlocked. So far nothing has worked. I will look at that webpage. Thank you.
    It was definately set up right the first time. We have used it and the lady that lived here before us had it too. It was working and then it started doing this a week ago. Any other thoughts?
  • 706 Answers
Have you tried unplugging it and then reapplying power after a few minutes? Sometimes a power down/up cycle will reset the logic..
Posted on Sep 21, 2008
4 Suggested Answers
SOURCE: Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Posted on Dec 08, 2007
heatman101
  • 43501 Answers
SOURCE: Stuck in clean mode. Ge Spectra xl44 My wife
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Nov 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Code e2 f3 appears, oven goes to self clean mode,
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%
Posted on Sep 29, 2010
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
I am trying to clean the lower oven of a double wall oven... GE True Temp self-cleaining. However it seems only the upper oven turns on to clean...will the lower oven kick in later on? There is a STD and...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | GE JBP71 Electric Kitchen Range
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
heatman101
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I'm trying to self clean the oven. I am following steps in the manual- however, when I press start to self clean, the door lock light flashes, then beeps and the oven turns off. The manual says the door...
heatman101
Nov 23, 2010 | GE JTP15 Electric Single Oven
I went to use the auto clean on my oven....turned the knob to "auto clean" then turned the oven door latch to the right to lock it. i found out the auto clean took 4 hours (don't have time to do it today)...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 08, 2010 | Hotpoint RB787 Electric Kitchen Range
The oven is stuck in self-cleaning mode and when i try to turn it on to bake the self-cleaning light just flashes what do i need to do?
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 06, 2010 | Kenmore 46564 / 46565 / 465 / 6646569...
When I turn the oven on, it goes into self-cleaning mode.
This sounds to me like your oven may need a new controller board. :(
Dec 14, 2009 | Washing Machines
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Self cleaning oven
it sounds like a micro switch is stuck they are located behind lower back panel
Nov 21, 2007 | Hotpoint RB757 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
492 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
