Question about Acer Aspire 5315 Notebook
Cd drive hello, the cd drive on my acer 5315 does not work, it used to put now the cd spins and the little green light is on but then it goes off then nothing happens
    Problem Solver:
  • 13 Answers
Hi my name is Mervin
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or wich is available close window and restart the PC it will work
This is common on the Acer products
if youn need help let me know
kind regards mervin
Posted on Sep 21, 2008
When I put a cd or dvd in the drive computer does not recognise there is a drive at all it is an acer 5315
consider to replace your dvd rom, because maybe it caused the dvd or cd cant read the cd or your dvd, maybe it caused the optic (head) of your optical drive is weak because of thr dust or dirty, before you replace your optical drive you can try to clean the optic using dvd or cd cleaner
Jan 16, 2011 | Acer Aspire 5315 Notebook
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
My accer 5115 laptop wont boot up it shows the green light when i plug in the power cord and wen I go to turn it on both lights light up and then go off. please help I have put in a new hard drive and it...
Use the OS CD/DVD to boot again and repair the OS. Next get the appropriate drivers compatible for vista from this site and install them on your laptop for it to function properly:
http://www.laptop-software.com/acer-software/acer-aspire-5315-notebook-driver-software/
Nov 11, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5315 notebook i put a new hardrive in my computer what do i do next to get it working afriend tried to down load windows7 but nothing is happening
Hello John,
Please confirm whether this new Hard drive is a secondary Harddrive, or this is the Primary (only) HARDDRIVE.
If it is secondary then it should work automatically as soon as you connected it through the USB Channel.
If it is primary, then after connecting the HDD, You need to put the Auto installable CD/DVD of windows 7 in the CD rom. It should detect the CD/DVD and startinstalling the windows 7.
Just follow the steps which comes your screen and it will be done.
WIth regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 11, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Cd drive not working
Most likely solution? Remove the drive and replace it with another one. Sounds like it's died physically.
You can call Acer Support to order just this part @ 866-695-2237
If this unit is still under warranty, then you need to get it looked at for free by Acer. One starting point is to go to the Web:
http://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
Another would be to contact whoever SOLD you this unit. Be aware that most factory hardware warranties are good for one year, and are not transferable, so if you bought it used, there's likely no warranty for you.
Finally, you could take your laptop to a reputable computer repair shop and ask them about replacing the drive or at least ordering one for you. I'm not personally familiar with this model, but many of the manufacturers are making the replacement of the optical drive an easy end-user fix.
Good Luck, Jim
Dec 02, 2009 | Acer Aspire 5315 Notebook
Have an Acer 5315. Used the system's restore
Disconnect any external devices, plug in your power to a A/C outlet, re-install the restoration disk and start over.
Check your BIOS again to make sure the CD is the first boot drive. You may not be saving the BIOS change or the restore disk may not be bootable.
You can check the restore disk on any PC or laptop.
Also you may have a restoration partation on the hard disk. Get you docs. and check.
Sep 20, 2009 | Acer Aspire 5315 Notebook
Acer 5315 elock
Go to device manager and click on your dvd/cd drive. Double click on this and enable the drive.
If driver is missing, go to Acer's website and download your dvd/cd device driver.
Dec 08, 2008 | Acer Aspire 5315 Notebook
A135 S2386 black screen
black screen with a orange light on cd drive hard drive light for a few seconds and goes off
Lubos
Aug 05, 2008 | Acer Aspire 5315 Notebook
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
48 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
