Question about ASUS Eee PC 900 16G Notebook
Computer will not connect to wireless router
I am not able to connect wireless.   Some times get weak connection.  Most times when connecting shows a strong signal from the wireless router, however will not connect and says to check weak signal.   I took the computer to a Starbucks to try other networks and had the same problem.
Wired connection works fine. cannot connect to wireless network. Initially was able to connect, but no longer. Others can connecticut to network.
  • 84 Answers
The antenna wire sounds pinched it is in the usually in the lid and can be found by looking in the hinge area
Look to see if it is kinked
LB
Posted on Sep 21, 2008
How can I troubleshoot My router? It is turning on and off all time.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 16, 2013 | Computers & Internet
Router disconnects several times weekly.
Feb 19, 2013 | Zyxel Prestige P-330W Wireless Router...
My WRT54G2V1 is now producing a poor or weak signal to the 20nd computer. I have reset it and poeered it down a couple times
Oct 24, 2012 | Linksys Computers & Internet
My router disconnects all the time
Sep 28, 2012 | SMC Computers & Internet
My computer looses conectivity
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Jul 11, 2012 | Compaq Presario R3210us Notebook
Hi everyone, I have a D Link DSL 2640U wireless router.I have been facing problems with connection stability for some time...the problem is that I have to keep my laptop switched on, so that I don't loose...
An unstable connection can be caused by any number of things, especially a weak signal.
Try moving the wireless router higher location away from concrete walls and or to a central location.
To improve the wireless connection, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Dec 28, 2010 | D-Link Computers & Internet
Upstairs computer no longer connected. Need to
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Dec 08, 2009 | Belkin (F5D7230-4) Router (587009)
Having trouble connecting. I see my encrypted router, but it shows as "unknown." And when I try to connect with it, connection fails. Says not in range although I'm in my own house. :o)
you said that you can see the wireless network but it shows as unknown network
I think SSID broadcast on your wireless network must be disabled.
You will need to enable the SSID broadcast of your network.
Also try to change the wireless channel on the router.
WRT54G router's IP address will be 192.168.1.1. if you have not changed it.
Do you have any other computer connected to the router woth the ethernet cable ?
If you do not have the computer connected to the route then connect 1 computer to the rotuer with the ethernet cable.
Do not change any wireless setting on the wireless computer.
You will need to open the set up page of the router
Click Here for more info about how to change the wireless settings
Nov 13, 2009 | Linksys Wireless-G WRT54G Router
Belkin Nimo wireless router internet drop outs
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
ASUS Eee PC 900 16G Notebook Logo
219 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
