My liteon dvd player/recorder used to write/copy to dvd discs but will not now either write or playback previouslt recorded discs - message states incompatible media. what has changed.
  • 84 Answers
Check you DVD flavor is it a + or -
Most Lite -On units use DVD +R
LB
Posted on Sep 21, 2008
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
Unsupported discs
Hi there
I think your DVD Player could have been damaged while it was in storage, this sounds like there is a problem with the lens (laser), i am going to suggest that you take it to a repairman and ask him to fix it or buy a new laser for your DVD Player attempt to fix it yourself.
If your DVD player is still under warranty, you should take it back to the retailer and have it repaired or refunded.
This could also be caused by "un-married" Player and Disc, if you bought the DVD Player in one country and bought the DVD's in a different country, this could also cause the problem. If the DVD's are copied, that could also cause it.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 5692f33.png if it helped you.
Kind regards
Dustin Ellse(BearWeb)
Jul 03, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Copying from HDD to DVD
There is no legal way around it, They do this to prevent priacy. There are ways around it but I am not sure about posting things like that on this site.
Sorry
Carl
Feb 07, 2008 | Computers & Internet
My JVC DVD recorder is refusing to playback one of my PHILIPS DVD-RW discs notwithstanding I have rec orded material on to it from the TV. The player is rejecting this particular disc coupled with a...
Did you record the disc on this DVR? Does it play in other DVD Players?.Try cleaning the disk with a soft cloth.Some DVR and Discs are not compatible.Good Luck.
Sep 05, 2009 | Televison & Video
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Jan 01, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Dec 11, 2007 | Lite On LVW-5045 DVD Recorder
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Playing disc
any disc recorded on the liteon must be "FINALISED" before it will play on other machines.use "disctools" in the liteon menu to tdo this.
Sep 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
