Question about Sova Digital DS205-S32 Television
DS204D-S26 No Picture Soundis OK
DS204D-S26 No picture just a black screen, except when changing channels picture flashes on screen. Sound is ok
  • auri_98 Jan 07, 2009
    I have a SOVA 27 inch tv and the same problem! I took this tv to a repair shop and they couldn't find the part anywhere to fix this tv! My tv sound plays fine but no picture. The so-called "Check the power supply proper voltage supply" response is lame because it doesn't address where or how to purchase a new one, let alone how to fix it. Hey what are we supposed to be checking?!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Posted on Sep 21, 2008
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
No Picture. Sound is OK!
That type of problem is becoming all too common with plasma and lcd flat screens 32" and above. There are two boards inside the plasma tvs that are called the y-sus and z-sus boards. From my experience the z-board has been the most problem producer with that no picture and sound ok problem. However, the one issue here is that the power to the to the y board goes through the z board. Most techs I know recommend replacing both. The reasoning being that whatever caused one to go bad would also weaken in some way the other. I am not fond of this type of thinking but since I do not have the tv in hand to take signal and voltage measurements I would start with the z board. On the internet you can probably find those boards and through e bay at a good price. They are not hard to spot once you take the back cover off the tv. The y board is usually on the left and the z board on the right. They have like 6 to 8 screws holding them in and three or four connectors that are keyed so you cannot plug them back in wrong. They are also clealy marked on the board itself and usually with a white sticker of some sort. New these boards can cost from $100 to $200 depending on the source. Shopping around you can find it worth fixing in my opinion if you can replace the board your self. Always disconnect all power when you take that cover off. Good luck and God bless. Roberto
Jan 08, 2009 | Sova Digital DS205-S32 Television
Tv screen not work
No picture, FR406 ok
Check the video output amplifier stage for failure
Display dead rest of functions ok
Change transistor Q1701 on Timer operation board
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
Screen is blank with sound working
i just fixed mine by doing this. on the remote there should be a button that says f. hold down the f button then press mute and that should work it did for me
Apr 02, 2007 | Polaroid TTM-2003 Combo
Televison & Video Logo
142 people viewed this question
Top Sova Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sova Televison and Video Expert? Answer questions, earn points and help others
