Question about Jenn-Air JMV8208AAS Microwave Oven
Change a JennAir JMV8208aa Microwave light bulb
Is there a trip to getting the light bulb out? And what is the part number of bulb?
  • Jenn-Air Master
  • 9,086 Answers
Inside light
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
2. Remove grille.
3. Remove screws securing bulb holder.
4. Remove light bulb
Cooktop lights
2. Remove lamp cover or remove screws securing bottom plate cover.
3. Disconnect lamps.
If your bulb is stuck or physically broken, it can be a pain. It's sometimes tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
The lamps are available at most grocery stores, hardware stores, home centers, and places like Wal-Mart and Lowe's.
If the unit uses halogen bulbs, do not handle them with bare hands, as oils from the skin make them run hotter and shorten their lives.
Posted on Sep 26, 2008
  • Martha B Cooley Jan 04, 2012
    Hello. My inside light bulb burned out some time ago. I finally took the time to see about replacing it. I removed the grill after turning off the power. There is absolutely no way that I can see to get the screw out of the bulb cover. It is on top and there is only 1 to 2 inches at best above it. If it took an allen wrench I could do it with an L shaped one but it is a phillips head. Really miss the light inside as I am 5'1" and have a little trouble seeing in it with the light and can't at all without it. Any suggestions??
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
Mar 14, 2015 | KitchenAid KCMS1555SSS Microwave Oven
Is there an internal reset button?
The short may have blown an internal fuse.
Jan 20, 2015 | LG LMV1630ST Microwave Oven
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
I replaced the light bulb under the unit on my microwave and went to turn it on and it tripped the circuit breaker and smoked the control panel. The only fuse in the unit is still good. Any thoughts?
< - Please let me know your full model number from the tag on the unit and I can can give you the repair information you need.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 05, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Jennair jmc8130dds fuse blown
I apologize for not getting back to you sooner. It took me a while to locate the information you requested. To answer your initial question, "YES" you will have to pull the whole unit out to access the fuse. The fuse is located on the input filter assembly board inside the oven. You will need to remove the exterior case to access it. If you go to pcappliancerepair.com you can find helpful illustrations, along with part numbers. Just type in the model number you provided and look at drawing number 5. This is a list of all the internal controls. The fuse is listed as item number 4 in the illustration and mounted to the filter assembly (item 18). You can purchase these appliance fuses at any hardware store as long as they are rated the same (20 AMP). CAUTION: Please ensure you UNPLUG the unit before servcing any internal components. I hope you find this information helpful. If you need additional assistance, please let me know.
Nov 23, 2008 | Microwave Ovens
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Burned out light bulb
can u open the housing?. you can look at the spot where the light is and you can see a bulb holder screwed on the metal housing. it has two wires hooked up to that holder. remove those wires and unscrew the holder of the bulb. look closely at the bulb if it is fiited to the holder like an ordinary light bulb. if its like that then you can unscrew it and replace it. if its not screwed to the holder then you have to buy the whole bulb assembly at the dealer of your microwave. it is considered a special bulb only from the dealer you can get. i hope i was able to solve your problem..
Feb 18, 2008 | Microwave Ovens
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
GE JVM1651 Microwave
The control circuit board needs to be removed and repaired. We routinely repair these from customers nationwide for $32.50. It sure beats the cost of a new board!
Sep 11, 2006 | GE JVM1651 Microwave Oven
Jenn-Air JMV8208AAS Microwave Oven Logo
1,060 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
