Question about Sanyo DS27510 27" TV
Can not get out of No input signal
We are hook up to direct TV and trying to adjust color we got onto No input signal how do you get out of that?
  • 70 Answers
Select the input button on your tv remote push it with a pause between pushes it will go back to the correct input some remotes have different names for input such as source or video but its the same thing
Posted on Sep 21, 2008
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
Trouble adjusting the color.. NO reds and can't seem to dial them in. Thanks, Chris
Recheck ur tv incomming broadcasting signal cable wire like hook it up to another tv,see if another tv is getting the red color,if not the incomming signal wire is the problems.If it the tv problems,than the tv Tuner signal board is dying,require changing the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Apr 17, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Signals to the tv from other sources and the image is P and G
Soon as though you have your wiring mixed up. Those leads, colors you describe are for Compnent Video signal....Red Green Blue. Now  the Others  are for Audio Visual signal , Yellow, Red, White... They are NOT compatable. IE: You cannot mix them. Check in your manual as to what  types of lead is needed how to wire it up..
Feb 01, 2010 | Televison & Video
Distorted Picture
I don't think that the cable is your problem. Set may have a defective tuner or small signal board. (Tuner is soldered onto the small signal board).
Most likely fix is to find and replace the small signal board with tuner. Should be able to find one for less than $200.
Another thing to try is your video inputs. Use external devices such as a DVD play hooked you using proper video lines and check you inputs. Are they doing the same thing as your cable? If not, then it maybe just a tuner. Some makes and models won't allow you to solder in a new tuner without a full board replacement, but this however may allow you to hookup a VCR with a tuner built in and from VCR to your TV using video input jacks and then programming the VCR tuner to all your cable channels may get your set watchable again without having to tare it apart and replacing a board. However if your input jacks are distorting like the cable channels are, then a small signal board replacement is a must for your set.
Jason
Dec 29, 2008 | Sylvania 6626LCT 26 in. LCD Television
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
Dark colors Picture going out
It is hooked up to Direct TV. When I change the channel on the TV to another input it looks fine but without a picture. as you do not see tint in another channel means your color section is ok it is due to video or luminance section.
Sep 13, 2007 | RCA TruFlat 27F520T 27" TV
Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Aug 04, 2007 | Sharp 27F-630 27" TV
Sanyo DS27510 27" TV Logo
162 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
