Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Hoover wind tunnel + cyclonic
How can I clean out the red top part below the filter. I am afraid to twist
in case I break it.
  • 120 Answers
Im pretty sure there are a series of screws that hold it together ( look down into the bottom of it ) once those are all out then it should just pull apart. be careful if it fights you than double check for any other screws you might have missed, they don't make them easy to find.
Posted on Sep 22, 2008
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
My Hoover UH70040W Wind tunnell mach cyclonic has stopped sucking up debris. At the brushes you feel no suction and when you disconnect the tube on the side it has some suction but not much at all. The...
Well if the vac motor is good then its either a clog or a leak ,if you say no clog then it has to be a leak. Make it blow out and see where the air is coming out or try and find it while it is running with a piece of typing paper loosly around the hose and piping. Seals at the connection areas go bad so check them as well.
Mar 31, 2011 | Hoover UH70040W Bagless Upright Cyclonic...
Can not find a proper fitting v-belt to fit my hoover wind tunnel cyclonic. i even ordered it from hoover.
The correct belt is # 38528034 ( package # 40201200 ) This belt may seem loose when it is installed, because there is an "idler bearing" that pushes down on it when the handle is released and dropped back.
Mar 07, 2011 | Hoover U5780-900 Windtunnel Cyclonic...
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Low suction when using attachments
Have you cleaned the foam filter? located above the dirt tank after you remove it. the manual can be downloaded from the web site at www.hoover.com ; sounds like an obstruction in the hose or elbow on the back of the unit. the hose can be cleared with a broom hadle when you take the hose completely off the vac.
Jan 17, 2009 | Hoover U5780900 Bagless Upright Cyclonic...
Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Jan 17, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Dec 25, 2007 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
50 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
