Question about Whirlpool Refrigerators
Refrigerator light bulb
The light bulb in refrige is burned out. I can't unscrew it to get it out. It is in a plastic socket on back wall.
  • 706 Answers
Sometimes the bulbs stick a bit so I suggest you temprorarily unplug the fridge and spray a little wd-40 or penetrating oil on the base of the bulb.. then wait a few minutes for it to soak in..you should be able to remove it after that.. Wipe off all excess oil before reapplying power ..then install the new bulb.. Hope that helps..
Posted on Sep 21, 2008
Why would light bulb in refrigerator keep going out
Check the hot pin of the bulb socket, its probably loose or pressed flat. Pull it up a bit so it sits higher, then put the bulb back it should make better contact with the bulb and not burn out. Make sure you do this will the unit unplugged from the wall outlet.
Aug 16, 2014 | Kenmore Refrigerators
My light bulb burned out in my refrig...how do i replace it?
THE BULB IS HELD IN PLACE BY A SOCKET THAT CAN BE TURNED AND PULLED AWAY FROM ITS HOUSING. THEN THE BULB CAN BE REMOVED.
Feb 20, 2011 | Refrigerators
Remove & replace right turn signal bulb
The procedure is as follows:-- Working from the trunk:
1. locate the 2 retaining knobs (doohickeys that you fasten the trunk cargo net to) for the Hard plastic trunk liner near to and inside of the rear light assembly. Unscrew the knobs.
2. Pulling back the plastic liner, locate the 4 studs (threaded posts). 3 will be located vertically in a line, the fourth, outboard and lower. Using a 10mm wrench(small), remove 3 of the 4 nuts fastening the light assembly to the body. DO NOT remove the lowest nut of the 3 in a vertical line, as this does not fasten the light assembly. DON'T LOSE THE NUTS OR WASHERS.
Working from the rear of the car:
1. Hand pull the light assembly from the car body.
2. Remove bad lamp. Twist lamp socket and pull out of assembly. Pull lamp and replace with #3057.
Reassemble:
1. Test light prior to reassembly.
2. Ensure Gasket material for assembly and studs is intact, this keeps water/dust out and dampens movement (prevents rattling and increases the life of lamp).
3. Use Reverse instruction for reassembly.
-------------- The taillight/backup light/license plate light assembly is separate from the brake light/turn signal light assembly on the Buick LeSabre. No matter what rear bulb you have to replace, you must access the trunk area to do so. Open the trunk of the Buick LeSabre.Locate 7 nuts underneath the trunk lid (3 on each end of the trunk lid and 1 in the middle). Remove each one using a nut driver.Manipulate the trunk lid at chest level and gently pull the rear taillight assembly slightly away from the trunk lid.Locate the burned out bulb sockets and then remove the bulbs. Insert the new bulbs into the socket and test by turning on the lights before reassembling.Replace the tail light assembly by aligning the studs inside the predrilled holes in the trunk lid. Refasten the 7 nuts.Remove the cargo net if applicable to replace the brake and/or turn signal light.Unscrew the plastic wingnut that the cargo net is attached to. Pull back the trunk liner.Remove the 2 plastic wingnuts under the trunk liner.Pull the brake light assembly outward from the back of the LeSabre.Locate the socket of the burned out bulb and then turn counter clockwise 1/4-inch to release it from the assembly.Remove the old bulb from the socket and replace with a new one. Test the light before reassembling. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 07, 2010 | Buick LeSabre Cars & Trucks
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not working, freezer stll works
if you recently had light bulbs burn out in the refrige section and now the digital temp read-out is also dark,it will be your control board (motherboard) needs replacement as the bulbs burn out it causes a surge and ruins this board,its located in the lower rear area on the left lower wall in or on the inside back in a plastic case,open the case unplug the wire harnesses and remove the board,it will have some circuit trace burned and the plastic case will be discolored there
Feb 14, 2010 | Refrigerators
Light does not work in refrigator, it's not the blub.
Disconnect the refrigerator from AC Power. Remove the light bulb, get a flashlight and look into the socket the bulb screws into and see if there's any corrosion in the socket that could be preventing power from getting to the bulb. If there is corrosion get some steel wool or a scouring pad and thoroughly polish the inside of the socket, (CAUTION BE SURE THE REFRiGERATOR IS NOT PLUGGED INTO THE WALL AC OUTLET WHILE DOING THIS,) After cleaning the socket re-install the bulb and plug refrigerator back into the wall and see if it lights up,when the door is open, if it doesn't, the next thing to check would be the switch that applies power to the bulb when the refrigerator door is opened. It could be stuck or it may have gone bad.
Sep 04, 2009 | Amana Refrigerators
Refrigerator light whirlpool designerstyle
well there is no magic button to push or anything like that some times they get stuck in those plastic holders get a pair of work golves or heavy towel and unplug the unit then just twist it out if the bulb seperates from the base get a pair of needle nose plires and grab it by the base and twist it out
May 21, 2008 | Refrigerators
Refrigerator
possible that the bulb recepticle is losing contact with bulb, real common among refrigs that have 2 bulbs back 2 back in one socket.UNPPLUG refrig and try prying up the brass contact arm on bottom of socket assy.UNPLUG first, that contact is live!!!!!!!!
Feb 18, 2008 | Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
