Question about Bissell 7950 ProHeat Upright Wet/Dry Vacuum
Bissell 7950 it is moving no prob but brushes not sping and no vacing at all its belts are in place
  • yamaharider1 Apr 13, 2009
    What do i do if the beater bar doesn't spin freely?
  • 706 Answers
Appears that you may have all the belts in place but the beater brush is jammed and it can't spin.. the jam may also be blocking the vacuum port so that you don't get any suction to that area. I suggest you unplug the vac, then open the base section to gain access to the beater bar and check to make sure the brush can spin freely.. also check that the drive belt is properly seated on the shaft and that there are no obstructions in the vacuum port.. hope this helps you..
Posted on Sep 21, 2008
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
Turbo brush on bissell cleanview helix stopped spinning
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 07, 2012 | Bissell Cleanview Helix Deluxe Bagless...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Bissell pro heat brush is not spinning. the belt is on and spinning but brush is not moving
There are two belts a brush belt and a pump belt. For a kit with installation instructions contact
BISSELL Consumer Services at
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 19, 2011 | Bissell Vacuums
My bissell helix cleanview vacuums brush doesn't spin
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
Brushes won't turn
Look at the ends of your brushes were the brush piece attaches to the vacuum. Sometimes they are broken or just stuck. good luck
Dec 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat self propelled series 7950 won't spray water and pump belt isn't broken.
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
Sep 02, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Oct 20, 2007 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7950 ProHeat Upright Wet/Dry Vacuum Logo
127 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
