Question about Onkyo Audio Players & Recorders
Onkyo 6 disc cd player onkyo DX-C320/C220/C120 Unit can not read disc. It will search thru all 6 positions then quit.
2 Suggested Answers
mlapres
  • 757 Answers
SOURCE: I have a onkyo tx sr304 and a onkyo 6 disc player
The only possibility that comes to mind is that it may be causing a short somehow when the carousel gets to that position, maybe a broken solder joint. Another possibility is that there may be a foreign object stuck inside the player such as another disc that lost it's position.
Posted on Feb 25, 2010
What is the most likely cause of a "NO DISK" error with the Onkyo DX-C390 6-Disk changer? Would it be the laser pickup assembly?
Could be dirty laser lens, dying laser, faulty component,
Due to the complexity of multi-disk changers, it may be best to have the device looked at.
You can try running a cleaning disk through it first, but from your post, it sounds like this unit may have multiple problems and need tested by a physical person.
Nov 24, 2014 | Onkyo DX-C390 6-Disc CD Changer
ONKYO CD DX-C390 6 CD CHANGER NOT READING
No laser, means no laser. Typical symptom of laser failure. Most CD players can have the laser replaced fairly easily and cheaply.
Contact your local technician, and he should be able to replace it quickly.
Oct 30, 2014 | Audio Players & Recorders
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
Plays 1st disc ok...2nd disc ok has trouble seeing 4-6
Hello,that unit uses one laser and the tray brings each cd to that laser for it to be read.The fact that a particular disc is having problems leads me to believe the disc is at fault,look for scratches and/or fingerprints on its clear metallic side.
Feb 10, 2011 | Onkyo DX-C390 6-Disc CD Changer
I have a onkyo tx sr304 and a onkyo 6 disc player dx-c390.When my cd gets to disc 4 and 5 it shuts the receiver down.Whats up with this?
Feb 19, 2010 | Onkyo TX-SR304 Receiver
Discs not reading
first clean the laser lens,and if this not solve your problem change the motor disc spindle
Jul 13, 2009 | Onkyo DX-C340 CD Player
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX C220
The little drive belt that operates the CD lift mechanism is likely busted. I just started looking for belts now.
Dec 29, 2007 | Onkyo DX-C390 6-Disc CD Changer
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
90 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
