Question about HP Computers & Internet
CORRECT WAY TO SHUT DOWN. MY OLD COMPUTER A GATEWAY IT WAS NECESSARY TO GO TO SHUT DOWN IN ORDER TO DO THIS. I FIND NO SHUT DOWN ON THIS HP
    Genius:
  • 1,689 Answers
I am assuming this is Vista, becassue for some reason the shutdown button does not show up by default.
check on the link below on how to get them out so that you will be able to shut the machine down properly.
http://www.arsgeek.com/2007/05/18/how-to-make-your-vista-shutdown-button-actually-shut-down-your-computer/
if you have other questions please lemme know.
Posted on Sep 21, 2008
Why PC on and off button will not shut off PC ?
try holding down the power button for 5 seconds this will shut it down but this is not the correct way to shut down computer at all. you need to go start>control panel>hardware and sound>power options>click on the left side it says choose what the power button does>next window use drop down to tell it to shutdown.....but the correct way to shut down is start>shutdown
Aug 22, 2014 | Gateway FX6800-01e PC Desktop
Motherboard troubleshoot
Try removing the graphics card and any un-necessary PCI components, and plug monitor in using the provided onboard VGA slot.
Jun 08, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
My 3 year old HP Pavilion DV6605US keeps rebooting with a blank screen every few seconds. What should I look for in order to correct the situation? Shield509
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
one faulty lead will cause a computer to fail to detect a hard drive,continously reboot, shut down a computer
hope this helps
Jan 26, 2011 | HP Pavilion dv6000t Notebook
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
Boston Acoustic BA735 no sound on new hp computer
All you need to do is download and install the Vista drivers from Boston Acoustic. You should then be all set. Hope this helps.
Sep 06, 2009 | Boston Acoustics BA735 Computer Speakers
M-series gateway (m1629) press start button, nothing
Taken apart, looking for abnormal solder etc checked powers switches decided that this unit was acting like it may have shut down due to excessive heat issue. pulled battery on board, tested ok, re-installed everything and found that this unit now is active. Conclusion: I suspect the bios shut this unit down, hard reset correct this issue.
Aug 24, 2009 | Gateway Computers & Internet
System power won't shut down when Windows shuts down.
if same system asking about hp a1320n
drivers and bios updates
try upadating all to see if corrects
May 15, 2009 | HP Pavilion Media Center a1320n PC...
Gt5520 video card
Is this a PCI-E card? I will work on the assumption that it is. Unless you are running two video cards in SLI remove the old card, they make great paper weights. Be sure to only add/remove hardware while the machine is turned off.
Dec 20, 2008 | Gateway GT5220 PC Desktop
Monitor will not stay on
Same boat 1.5 years old and the screeen will shut down in about 1-3 seconds as long as i turn it on.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Display problem
A fuzzy display is not likely to by caused by programs on your computer. Is this an LCD flat panel monitor or a regular CRT monitor?? If it's a CRT, the problem could be with the high-voltage power supply, which would need to be diagnosed by an experienced computer1.gif or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 18, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
223 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
