Question about T-Mobile Dash Smartphone
Home screen not fully loading
Whenever my phone is turned off (battery dead, on flight) and I turn back on my home screen does not load all the way and the date time and clock is missing. How do I fix? Has this happened to anyone else?
Thanks!
  • marci916 Mar 05, 2009
    my dash will not show me the date or time and it moves super slow when I am trying to go from my text message inbox. it also does not let me know when i have a new message or incoming call. it just lights up.
  • charmingirl Mar 29, 2009
    i too have this issue from time to time. most times i just power it down and when it powers back up, it's ok. but today i have powered it up and down 2-3 times and it's still not showing the time or date.
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have the firmware flash back in the phone if flashing does not help then take the phone and have it exchange.
Posted on Sep 21, 2008
What should i do if my phone doesnt turn on completely to the home screen?
Which phone do you have? Are you getting any error messages?
May 01, 2014 | Kyocera Cell Phones
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
Jan 04, 2014 | Nokia Lands Phones
Keeps showing lg screen and flashing
Android is corrupted. You need to factory reset it. Hold volume down and home buttons while turning it on. You can let go of those buttons once the screen changes to the Android loading icon.
This will erase everything from your phone - so good idea to keep things backed up for incase it happens again.
Near as I can figure, this happens when:
- phone battery is allowed to die
- pull battery from phone when it is still shutting down (hard to tell when it's finish)
Dec 28, 2012 | LG Optimus Net P690 Touchscreen Android
My samsung infuse will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 23, 2012 | Samsung Cell Phones
Just bought a new LG Axis smart phone today and after loading some applications from the application market on the phone, whenever I went to view an application I kept getting an error message that the...
A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold
up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
Mar 27, 2017 | Cell Phones
My phone runs out of batteries so i took it home to charge it but it wont turn on, everytime i try it goes to a white screen as if it loading then shuts down again what do i do
if you have a usb charger for the pc you can do a trickle charge which helps when it goes fully dead another way that sometimes works is plug it in and while its plugged in remove the battery and reinsert in while its plugged in sometimes it allows it to charge.
Dec 03, 2010 | AT&T Cell Phones
Ok my htc hero was applying an update and it froze! i waited and my battery died on my phone. i then turned it on and it came up with the exclamation mark in a triangle with a phone underneath it. i then...
if you can get back to the exclamation point go to this site and download the ROM and follow instructions on loading it http://bit.ly/cDjVmV
Jun 29, 2010 | Cell Phones
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
T-Mobile Dash Smartphone Logo
60 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
