Question about Apple iPhone 3G
Can't get on internet
After I open the power of Iphone 3 G, it shows T for telphone call,
but did not show E, thus it doesn't connect to internet. How can I solve this problem ?
    Sergeant:
  • 196 Answers
Iphone uses wi-fi for first preference to connect to internet then drops to 3G if wi-fi not available then finally E (Edge) if you do not have either of those showing on your phone then it may be you are in an area where not even edge is available... try checking in different locations inside/outside your home.. down the street a ways or even a different part of your town. If you still cannot get at least the E on your phone maybe your service provider does not provide sufficient coverage for your location.. this does happen
Posted on Sep 23, 2008
IPhone weather app "update failed'
The easiest way is to wait for a few hours and try to update your iPhone again. Best remember to try this way because sometimes it really works well. And simply, I would like to introduce the steps to upgrade your iPhone via WiFi environment first and foremost.
1. Open Settings of your iPhone.
2. Connect WiFi and find General on your iPhone.
3. Open Software Update.
4. The device would automatically check for update, or you could click the "Check for update" button.
5. After that, click Install Now button. Then you just need to wait until the update completes.
http://www.leawo.org/tutorial/what-to-do-when-iphone-software-update-failed.html
Dec 20, 2012 | iPhone Apps
Why wont my iphone 4 turn on
Try connecting it to iTunes, and click on restore. If that doesn't work, try holding the power button and home button at the same time until the Apple logo shows up.
Jun 28, 2012 | Apple iPhone Smartphone
Iphone 3 doesn't switch on.
You probably, reset your phone setting, and if you were jail broken, 2 many factors would affect your device and cause this problem, 1-if you were unofficialy unlocked your device by ultrasn0w or Sam . 2-you may have updated your firmware via iTunes and that would lock you phone and cause that error, you need to searh iclarified dot come or modmyi forum
May 17, 2012 | Apple iPhone 3G
When i open my iphone it doesn t open it just stops at the apple acon what cn i do plzz tell me
1. Connect your iPhone to iTunes.
2. Hold the Home button and the Power button at the same time for 10 seconds.
3. After exactly 10 seconds, release the Power button but keep holding the Home button for 10 seconds or until iTunes pops up a message saying that it has detected an iPhone in recovery mode. At this point, click OK, then click "Restore" in iTunes.
Feb 01, 2011 | Apple iPhone Smartphone
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
http://support.apple.com/kb/ts2756
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Opera Software Mini
Pls. how do i update my jailbroken iphone 3g to the latest firmware
Do u need to keep ur data? if yes then u will need two different PCs/MACs to perform this?
get latest itune on both.
on one of the computer connect ur iphone and once connected to itune, right click on the iphone icon and select back up. All ur data is now backed up.
Now, Perform the steps below at ur own risk.
You will need to do the jailbreak again once upgrade done. keep in mind that the latest firmware iOS 4.0.1 can not be jailbroken and thus can not be unlocked.
Get ur phone in to restore mode by doing ,,
Turn off the iPhone comletely by sliding the red slider on the screen.
Open itunes on the other computer (not the same where u have backed up ur data)
Step 1
Open iTunes and connect the iPhone via USB.
Step 2
Press and hold the Home button and the Sleep/Wake button at the same time.
Step 3
Continue holding the both buttons until your iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
Your iPhone screen will look like this:
Click OK on the small pop up.
Now, select resore button on the itunes screen and itunes will find the latest upgrade for ur phone and will show u the recommended upgrade in to a small pop up in less then 3mins.
and there u go, select ok and let the itunes perform the rest.
Jul 23, 2010 | Apple iPhone 3G
Since reset all configuration i got only an apple sign from 4 day
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Jul 20, 2009 | Apple iPhone Smartphone
My iphone hang. Only shows apple ph. kindly help to restart & back to normal.
try this pls,,, Step 1. Turn off your iPhone.
Alternative Method:
Aug 31, 2008 | Apple iPhone Smartphone
Wierd connection wire and itunes picture on screen
Try a hard reset:
  1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
  2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
  3. The iPhone should now shutdown automatically - (fade to black)
  4. Turn the iPhone back on by hitting the sleep/wake button.
  5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
Then plug in your phone to a computer with the latest version of iTunes. Do a full restore to the latest firmware.
Mar 02, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
152 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
