Question about Whirlpool Dishwashers
Hi I have a dish washer problem. it does not drain all the way out. it is brand new just installed. Could it be lack of power? I'm not sure just guessing. thank you Ben
Hi ben,
I'm Harvey the Master Plumber.
Your problem is: You have a d/w problem. it does not drain all the way out. it is brand new just installed. Could it be lack of power?
Not likely. Probly something wrong with the control. It's new so don't touch it. Call warranty and if they can't fix it in a resonable amount of time then get a replacement from the sales person. If he wants your repeat business he'll take care of you.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
Electrolux dish washer not draining
Is it new? Or new garbage disposal installed? Make sure the drain pipe is punched out under the sink
Feb 11, 2017 | Electrolux Washing Machines
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
How do I test a used dishwasher before I install it?
Hi knowone has ever asked me that before but it can be done if you spend a little time You need to be near a power 120 volts plus water and a drain , if you look under your sink in your kitchen on the hot water valve you should be able to connect into the hot water , if you plan on hooking it up at this sink then go ahead and splice in a tap for water for the dish washer on the hot water you should buy a shut off type valve most times they use 3/8 , run the hose from the new water valve to the water valve on the dish washer then you need a drain that is the easy part run the drain hose from the dish washer right into your sink ,next you need power , down where the wires connect you will see a black wire and a white wire , if you have a old extention cord around that you can cut leave the end on that plugs into the outlet on the wall but cut the other end off , next open up the end of the cord to see the wires , if it has a green you dont need to use this for a quick test only if you want to , but hook up the black and the white then you should be all set to try it If i can help any more get back to me Frank
Dec 12, 2011 | Hotpoint Dishwashers
Dishes are not getting clean..glasses are covered in crud
Try refilling the rinse agent, and cleaning out the bottom of the unit. If the dish washer was resently installed. Or you have recently intalled or replaced your garbage disposal. Make sure the plug was punced out where the drain from the dish washer connects. If the plug is not punched out you will be useing the same water over and over agian.
Jul 20, 2009 | Dishwashers
Dish washer not draining
Try following:
  1. Check sink drain and drain hose for restrictions
  2. Unjam the motor
  3. Unjam the pump
  4. Check the drain valve
  5. Check the drive belt
  6. Test the timer motor
  7. If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
pls rate my suggestion...
Jun 24, 2009 | Westinghouse Dishwashers
Miele dish washer
I have a miele G 643 SCVI Ingognito the re-0cccurring prob is the the drain/intake light comes on quite frequently I have to cylcle the on/off switch twice to clear the fault. I have check the drain line several time w/o any obvious findings what's next
Feb 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
No Drainage Stoppage?
The drain hose has to be higher than the full water tub level or it will keep draining out make sure your hose is high enough
Feb 06, 2008 | Haier HLP21E Top Load Washer
Dishwasher will fill and drain, but will not cycle!
Bobalou If you just bought and installed, I'm assuming you dish washer is brand new. It means it has full warranty with Maytag. Do not do anything. It will void your warranty. Call Maytag authorized service. Gendos...post back
Jan 23, 2007 | Maytag 24 in. MDBH750AWS Stainless Steel...
Dishwashers Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
