Archos AV-700 Digital Media Player
Problem for Archos AV-700 Digital Media Player
CProblems onnecting Archos 700 after connecting 605 to PC
By BristolUK on Sep 21, 2008
HI, I have just upgraded to an Archos 605 wifi. All was fine and I was able to download everything, but since I have connected it to my PC, my old Archos 700 no longer connects to my PC aswell - as it shows as not recognised as a usb device. I have also tried connecting the 700 into another computer and still no luck.
I have also now plugged my 605 into my sister in laws pc, and now she is having exactly the same problem with her 700 - i.e it can no longer be recognised on her PC.....
Does the 605 download anything onto the PC, with can effect the 700 plugged in afterwards ?
Comments:
Sep 21, 2008
- Thanks for the quick response - but it seems to now be a problem with both 700's, as they cannot be connected to any PC - even if the 605 hasnt been connected to the PC.
It is almost as if the 605 has downloaded something onto the pc which was then uploaded onto the 700 on teh first reconnect that means you can no longer connect to any PC - we have tried 6 !
The Archos itself works fine apart from not connecting to the PC
Sep 21, 2008
- Hiya, It has actually now happened to two separate Archos 700's, once I plug my 605 into the Pc first....so I thinking that this is more than co-incidance.
They both actually work fine and I can still watch what is on them. But if I plug either in a PC they both come up with the error "USB device not recgonised"
Sep 21, 2008
- Have tried everything the manual has said to do - including those instructions, but no luck. Both the 700's had been previously connected to PC's a number of times, before this started to happen
Sep 21, 2008
- Hi,
Thanks for your response. Problem is that we have tried four PC's with both Archos 700's and none work, so dont think it is the USB on the PC
Sep 21, 2008
- one is the 700 with 100gb and the other is the 700TV...
Sep 21, 2008
- There isnt an option under settings-system to clear cache and tempory files etc.
Sep 21, 2008
- It is set up as hard drive...will I be able to update firmware when I cannot connect to PC ?
Sep 21, 2008
- If it is a driver problem - then how come every PC we now try has the same problem - even though the 605 was never plugged into some of them ?
Sep 21, 2008
- If plugged in the 700 is shown as do as an unknown device? If Unplugged the device dissapears
Sep 21, 2008
- Hiya - there is no option to clear system settings (I have the 700TV in front of me), it only has update arclibarary, update firmware etc
Sep 21, 2008
- Hiya - tried both Hard drive and media mode - but it is currently in Hard Drive mode. I couldnt find any settings for clearing temporary files on the Archos 700 TV
Sep 21, 2008
- Hiya - just checked and it is a AV700TV 40GB ...wish I had never upgraded to a 605 with all these problems :-(
Sep 21, 2008
- No - didnt find repair and formatting tools
Sep 22, 2008
- Was very patient, and came up with some very good solutions, when other experts were suggesting the obvious (but incorrect) solutions
Best Solution
posted on Sep 21, 2008
Very Helpful)
leethedeuce
Rank: Guru
Rating: 86%, 525 votes
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version?
Thanks,
Lee
Comments:
Sep 21, 2008
- Ok, then I may still need to get more information as it seems it may just be a problem with the 700. Now what is the exact error you get when you plug in the 700? When you plug it in is it recognized?
You can also try a hardware reset
"In the event that your AV 700 freezes operation (due to electrostatic phenomena for example), you can actuate a
hardware reset by holding down on the STOP/ESC button for 15 seconds. In normal operation, the STOP/ESC
button will shut down the AV 700 after being held down for 3 seconds."
Thanks,
Lee
Sep 21, 2008
- I believe this also may solve your problem I found it in the user manual.
"18.1 USB Connection Type (‘Hard Drive’ or ‘Windows Device’)
Your device comes confi gured as a Windows® Device and will be immediately recognized by your
computer if you are running Windows® XP (with Service Pack 1 minimum) and Windows Media® Player
10. If you have another version of Windows®, not sure what version of Windows® XP you have, or if you
are using a Macintosh®, then you will need to change the USB (Universal Serial Bus) Port setting on
the AV 700. You will do this by going to the setup action icon and then to System and USB Port and
change it to ‘ Hard Drive ’.
18.2 Connecting the AV 700
Connection order: See the sections below for your particular computer’s operating system.
1) Connect the power adapter to the AV 700.
2) With your computer running, plug the USB cable into your computer.
3) With the AV 700 off, plug in the other end of the USB cable to the AV 700 USB Device port.
4) Turn on the AV 700. (If your computer asks to install a new driver for the new hardware, then you must unplug
it and change the USB Port to Hard Drive.)"
http://www.pocketdish.com/EN_AV700_v18.pdf
here is a link to the manual as well for future reference.
If you have a moment to accept and rate my solution I would greatly appreciate it as I strive to provide fast, economical, and accurate solutions. If you still need assistance let me know.
Sep 21, 2008
- Is it the 705 or the 704?
Thanks,
Lee
Sep 21, 2008
- In menu>setting>system its in the repair and formatting and tools. Clear temporary system files and cache. Also is all the firmware up to date? and is it in the correct mode? You need to have it hard drive mode if your using it like a pc hard drive or if your using it with media player it has to be in media player mode. If these don't work then we will have to move on considering a reformat or full initialization.
Thanks,
Lee
Sep 21, 2008
- I'm sorry I am wondering why you rated me a thanks for trying? I have not finished assisting you, also I am not suggesting it's a USB problem. The steps I have suggested are exactly what you need to do to figure out what the problem is. If you have done these please let me know and we can move on from there. If you could reconsider your rating and accept and rate accordingly that would be appreciated.
Thanks,
Lee
Sep 21, 2008
- Do you have the data that is on the 700 backed up already? If you are ok with losing the data on it. You can reformat it and re-initialize it. If you don't feel comfortable doing it step by step this way. Archos has great support and could run you through this in minutes because its over the phone, and you have the unit in hand.
Toll-free number is: 1-877 300 8879
Hours : daily 7:00am - 11:00 pm CST, 7 days a week
No you cannot update the firmware if it will not connect. Though for future reference you want to check to make sure periodically that you have the most up to date firmware. Archos would be able to tell you if your version is old or not. If you still need any assistance I am here.
Thanks,
Lee
Sep 21, 2008
- I am not suggesting it is a driver problem.
Sep 21, 2008
- I don't believe that it is necessarily a driver problem because in hard drive mode it doesn't use a driver. I think you may be out of your range of expertise on this one Ginko. Did you do as I recommended and cleared the temporary system files??
Thanks,
Lee
Sep 21, 2008
- Once I know if you have tried clearing the temporary system files we can move on from there. If you have found my assistance helpful you can accept my help and I can still assist you further if need be as I would be more then happy to.
Thanks again,
Lee
Sep 21, 2008
- So you double checked that it is in hard drive mode correct? Also did you clear the temporary files yet. This will not delete anything vital. It may resolve the conflict. Can you connect in media player mode to windows media player?
Thanks,
Lee
Sep 21, 2008
- The TV's model should be the 704TV.
Sep 21, 2008
- Did you find repair and formatting tools?
Sep 21, 2008
- Toll-free number is: 1-877 300 8879
I highly recommend you try their tech support line. They are very very helpful and can run you through the troubleshooting better then anyone because it is their unit. If you aren't ok with trying this let me know. If you are let me know the results as I am confident they will be able to figure out your problem. At worst I believe that a format or re-initialization will help which they will walk you through and it shouldn't take very long.
Thanks,
Lee
Sep 22, 2008
- Thank you and your welcome. I was wondering if you ever solved the problem?
Thanks,
Lee
Rating Locked! (?) BristolUK has rated this solution as Very Helpful
Solution #2
Somewhat Helpful)
ginko
Rank: Guru
Rating: 89%, 5259 votes
Archos 700 and Archos 605 have different drivers. If you connect both to the same computer the divers can be damaged , and you may need to reinstall the drivers.
Reinstall the drivers for Archos 700 , if they still do not work together, there may be no way to have both drivers working.
Comments:
Sep 21, 2008
- It is a driver problem, as stated.
The thing that you think it is uploaded on archos is instead loaded on the system, on Windows. It is a typical driver conflict, as soon as you connect the archos the system try to recognize it and mess up drivers. That is all.
Sep 21, 2008
- More : the driver for all archos are the same, they are not downloaded but wrongly installed automatically by windows.
You can attempt to solve the problem by installing the drivers by yourself before connecting the player.
Sep 21, 2008
- you stated "but since I have connected it(A605) to my PC, my old Archos 700 no longer connects to my PC" " plugged my 605 into my sister in laws pc, and now she is having exactly the same problem with her 700 -"
That means when I connect A605, A700 does not work.
Now you tell me : "If it is a driver problem - then how come every PC we now try has the same problem - even though the 605 was never plugged into some of them ?"
what does it mean? that is in contradition with first statement! Does it mean that your A 700 does not work on any computer on earth?! then is broken!
Do a system restore to before installing the new A 605, or reinstall A700 , the computer will work back with a 700 unless you plug in A605 again.
Or keep the A 605, there may be problems connecting A700 and A605 to same System.
If it was an usb problem the computer won't work with either device.
Solution #3
Not Rated)
Ekse
Rank: Guru
Rating: 88%, 4871 votes
Hey, try uninstalling the usb ports and usb devices from device manager and restart the pc, follow instructions I have posted here
http://www.fixya.com/support/r569923-usb_devices_not_recognised_or_not
let me know how it goes.
Comments:
Sep 21, 2008
- Also note if you see the device in device manager when plugged in. if it has a ! or ? mark let me know, also right click properties, whats the status if it has a ! or ? mark.
Sep 21, 2008
- Have a look into the device manager, do you see the device there or as a unknown device? Unplug the device and see if it dissapears or appears.
Sep 21, 2008
- to open device manager
1. Hold down the windows key and press r
2. Type devmgmt.msc into the run menu and press ok
Sep 21, 2008
Sep 21, 2008
- you may have a faulty usb (in the device not your pc), or a software issue (in the device not your pc), try reseting the device. also check if it appears in device manager.
Popular Solutions for Archos AV-700 Digital Media
Questions and Unsolved Problems for Archos AV-700 Digital Media
Do you recommend Archos AV-700 Digital Media Player?
Answer
Answer
buzzing/clicking sound through speakers .music+video .But ok with headphones ? unresponsive to... (More)
Answer
I have an ARCHOS AV700. IT WAS DROPPED AND NOW WILL NOT WORK. WHEN I TURN IS ON THE BLUE SCREEN... (More)
Answer
wheres the factory reset on the archos av 7oo it is totaly dead
Describe your MP3 and Digital Media... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , PA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
