Question about Honeywell Heating & Cooling
Honeywell AWH 629QE A The electronics in the heatpump is broken after that a lightning struck down near us. Are possible to get a new electronic card and schematic so a can fix the heatpump? Ing Tony E in Sweden
SOURCE: how to understand schematics?
give a cheat of need for speed hot peir shut
Posted on Mar 08, 2008
  • 67 Answers
SOURCE: Tv struck by lightning
You wont be able to fix the TV your self as the power circuit board may have blown - consult a qualified repair man. Buying a surge protector for your expensive electronic goods is highly recommended.
Posted on Jul 10, 2009
greenspan
  • 1734 Answers
SOURCE: Schematics for Miele Microwave M637-1EC Electronics
Ask them, they can get you many Miele schematics.
Posted on Jul 14, 2009
  • 1138 Answers
SOURCE: I NEED TAN ELECTRONIC SCHEMATIC
Here is a link to the manual:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP1000/RP1000%20manual%2018-0597-A.pdf It is highly unlikely that you will find a schematic unless you know a service tech for a music store that deals Digitech. Also you will need some specialized tools. Here is their contact info:http://www.digitech.com/dealers/service_lookup.php If you are a tech you can always contact them.
Posted on Apr 09, 2010
shastalaker7
  • 1515 Answers
SOURCE: TROUBLE REPLACING OEM TIMER - UNIVERSAL ELECTRONIC FAN TIMER
Hi, you should be real close with the universal timer and the factory OEM. On the new control board, if you have 24 volts to the board, you should have 24 volts from R to ground or to Common. I know that on most all control boards the voltage in is 120volts as you will have terminals for L-1 and L-2 to run the high voltage controls from the board and all of the thermostat control terminals in a row, R,G,Y, W, C, and so on are 24 volts. 120 volts is stepped down to 24volts control and you say you have nothing out. Make sure you have 120volts in. You are calling this a timer board, is this a heat-pump defrost board with the 3 settings and pin to defrost the unit at 30,60,and 90 minute times? This is what it sounds like. If all was terminated per diagram, you would have the 24 volts required to fire this unit. These defrost timer boards require high voltage to them as well. Even though the board is a new board and you know for a fact that it is wired properly, it may be a defective board. I have seen this many times in my years as a tech. I have shorted new boards out by static electricity and by mis- wiring one. You can kill power and look at the back side of the board to see if this has happened. Sometimes you will find that they missed a solder point on the back side not completing a circuit through the board. To give you more ideas, I would need to see the diagram, or if you could send me the model, serial, and name of your unit. The board number would help also. Check out what I have said and get back to me on this. I will wait to hear.
Shastalaker7
Posted on Jun 06, 2010
How do I diagnose and fix an LCD HDTV whose screen will not come on because of possible lightning strike?
needs circuit testing doubt you would actualy be able to see any damage to circuit boards doesn't take much of a power surge to knock one out tv engineer needed
Aug 25, 2015 | Televison & Video
Struck by lightning no power
Lightening is always a killer of electronics. Have the unit serviced and the power supply replaced.
Aug 04, 2013 | Element Electronics Element 50" Class...
Hi I have a Sony STR-DH510 that was struck by lightning and would like to fix it myself ,new in elektronics. Johan
As you are new to electronics it is not something that i would suggest, generally items struck by lightning are considered a total loss as the damage is massive, you have to replace every diode, IC and voltage regulator, also most if not all of the electrolytic capacitors will need replacing and parts will cost more than buying a new one.
Mar 12, 2012 | Sony Audio Players & Recorders
Will not heat baby food for 13 seconds
Depending on the amount of Joules your household/microwave received your low voltage control electronics may have been fried by the lightning strike. For your own safety I recommend a new microwave.
Jun 10, 2010 | Maytag MMV5186A Microwave Oven
I Have a honeywell RTH2410 Thermostat I wired it without the blue wire which used to go to X on my old thermostat. Now it comes on with aux heat all the time and I have a Heat Pump. How can I fix this?
What was the old thermostat labels and the wire colors that went to them?
The typical heatpump wiring Terminals are:
R = Red = Hot side of Transformer
C-B-X = Common side of transformer Depending on brand of heatpump
Y = Yellow = Cooling Contactor
G = Green = Furnace Blower
O = Orange Reversing Valve Energize to Cool
B = Blue Reversing Energise to Heat Depending on brand of heatpump.
W2 = White = Auxiliary Heat
You need to be sure where each wire comes from when you connect them to the new thermostat.
The best way to do that is to go to the furnace and see where they are connected. R-Y-G are probably correct, you need to see where the Blue wire comes from and determine what the X terminal was on the old thermostat.
Dec 29, 2009 | Honeywell Electronic Programmable...
Lightning struck and took out my dell ethernet card adapter? Is there anywhere I can buy one to replace it?
Yes you can buy a replacement Ethernet card from any electronic or computer store near you and they are pretty cheap now...
Dec 16, 2009 | Dell Ethernet Card Network Adapter
Jul 10, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Lightning struck the cable tv line coming into the house. All of the electronics connected to the cable quit working. I took the back off of one of the tvs, and could not find any sign of scotch, burn,...
A lot of electronic devices have built-in on-board surge suppressors such as MOV's, and avalanche diodes - these could get damaged during a lightning strike. Fuses are another possibility. Beyond that, gotta take out your DMM and oscilloscope and start troubleshooting, or see a technician.
Aug 26, 2008 | Televison & Video
Heating & Cooling Logo
105 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
