Question about Samsung LN-T4671F 46 in. LCD Television
PIP for Samsung 550
I recently bought a Samsung 550 TV and do not know how to install the PIP. Can someone give a step by step instruction on how to install?
joeymille916
  • 143 Answers
SOURCE: How do I hook up
The manual is here... http://downloadcenter.samsung.com/content/UM/201007/20100708133121375/BN68-02698Q-00Eng-0607.pdf The PIP instructions are on page 20.
The PIP will function using one source (thru Component, HDMI, etc.) and another being the TV tuner. THE PIP by default is thru the TV Tuner.
Posted on Oct 12, 2010
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
I'M INSTALLING A NEW REMOTE. IT CONTROLS THE SAT RECEIVER BUT NOT THE SONY TV. IT WILL NOT GIVE VOLUME CONTROL NOR TURN ON OR OFF THE TELEVISION. I'VE TRIED THE SONY CODES TO NO AVAIL. SUGGESTIONS?
rl_harris679
I have provided a link with instructions on how to program the new remote to your Sony TV. The link contains our different receivers. Select your receiver model, then a PDF document will open with the instructions for programming the remote to your TV. It begins with step 5. I hope this helps.
Programming the remote to TV:
http://www.dishnetwork.com/SupportSection/remote-setup
Sony TV codes: 500, 590, 000, 002, 073, 511, 514, 546, 550, 567, 578, 640, 670, 690, 758, 778
Ray Calo
DISH Network
Feb 19, 2011 | DISH Network IR Remote Control
How do I hook up PIP on my Samsung 60 inh Series 6 LED TV. Pictures and instructions please. Thank You!
Oct 12, 2010 | Samsung Televison & Video
SAMSUNG SERIES 5 550 THE TV WILL TRY TO COME ON AND THEN SHUT DOWN AND START OVER.
Most likely failed capacitors in the power supply. I recently had the same problem with my 26 month old Samsung LN46A750. Samsung paid for the installation of an upgraded power supply board.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Aug 27, 2010 | Samsung LN52A550 LCD TV
Regarding PIP (Picture in picture) facility
Sorry to say, you may not be able to do this. This will require you to have multiplexed inputs going into the TV. The out from the Tatasky set top will give out only one channel at a time.
Jun 21, 2009 | Sony Televison & Video
How do I install front & rear bumper covers on a 1999 Honda CRV?
hi there try this site for a full manual for your car
http://www.haynes.com/products/sfID1/3/sfID2/5/sfID3/62/listPage/2/productID/202
it will give you a step by step instructions for your repairs
regards JR
May 29, 2009 | 1999 Honda CR-V
Switch out a dashboard in an 85 regal
sign up at turbobuick.com (it's free)..I can almost guarantee that someone there nows how and will give you step by step instructions
Mar 20, 2009 | 1985 Buick Regal
Can install a printer
Someone has given me a Samsung ML-1510 but no CD. I dont know how to install the printer at all. I have tried to follow the advice that others have given on here but its not very clear and i seem to be getting lost. Can someone please give a step to step guide in how to to do it?
Aug 18, 2008 | Samsung ML 1510 Laser Printer
My tv
This set is known for some very common problems some of which is just what you described. For a small fee, I can give you some common solutions that will take care of these and other issues. The only problem is you must know how to take things apart and put them back together without doing further damage, AND you must know how to solder /desolder components.
Dec 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Magnavox pip
PIP requires either multiple tuners, or another video source. It sounds like your tv lacks another tuner. Does the tv have inputs for, say, a vcr? If so, connect a vcr to it, play a video, and then select PIP. It should display the video and tv simultaneously.
Nov 13, 2007 | Televison & Video
Samsung LN-T4671F 46 in. LCD Television Logo
247 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
