Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Troy Built 4-cycle engine Trimmer
By mistake I added 2-cycle oil to trimmer. ugh! What kind of oil do I need to add.
Thank-you
  • 43 Answers
Usually 30 weight.
Posted on Aug 20, 2012
  • 163 Answers
There should be a label stating the oil type somewhere on the engine or cap or owners manual, if not most manufacturers recomend a 30 weight oil. be sure to drain out the old stuff first.
Posted on Nov 29, 2008
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Is there something that can be put in the fuel to keep the fuel line from disintegrating?
You can add a fuel stabilizer to the fuel to prevent that from happening. You should always add the stabilizer to new fuel and it can be used in all of your engines, everything from a string trimmer to your car. The ethanol in today's fuel is causing many problems, especially with 2-cycle and 4-cycle engines. You can buy Star Tron fuel stabilizer from PartsBuggy.com. A good size is the 8 oz bottle. It treats 48 gallons of fuel with one bottle.
Nov 30, 2012 | Troy Garden
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Never owned a 2cycle product and some one gave me a John Deere t105c trimmer but dont have an owners manual and dont want to pay $20 -$40 for one just to find out how to fill with gas/oil mixture. Can you...
You need two-cycle motor oil, do not use regular motor oil. Almost all two-cycle motors are designed to run on a 50 to 1 mixture of gas and oil. Look for two-cycle motor oil at any store that carries two-cycle tools like chain saws, line trimmers, etc. A good bet is Lowe's or The Home Depot. If you get the 2.6 oz bottle you have to add that to one gallon of gas to get a 50:1 mixture. Always read the oil bottle for correct mixing amounts and mix the oil with the gas in a separate container then put it in your trimmer.
Jun 06, 2011 | Garden
What fuel does my strimmer require - McCulloch 240
Most trimmers require a mix of regular unleaded fuel and two cycle oil...the ratio is usually 50:1...you can purchase the oil in convienient packages that allow you to add the whole package to 1 gallon of fuel to obtain the proper mix
Apr 24, 2011 | McCulloch Trimmer Plus Attachment: Add On...
Where do i add engine oil to the motor? Not the oil for gas
I think you are saying that this is a 2-cycle motor (like most gas trimmers), that you already use a gas/oil mix, and you want to know how to add oil to the motor crank-case. If this is your question, then the answer is that you don't add oil to the motor. There is no place to add it. Unlike a 4 cycle engine (like in a car or most lawn mowers), the oil/gas mix is fed through the crankcase and is used to lubricate the engine, then is also used as fuel. good luck, Al K
Mar 01, 2011 | Homelite Mighty Lite Lawn Trimmer
How much oil to gas do i add
You need to make your gas:oil mixture 50:1. 2-cycle oil bottles have instructions that tell you how much gas to add to them to make a 50:1 mixture.
Nov 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
521 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
