Question about Hoover Vacuums
Find the belt on a WinTunnel V2 TurboPower 7300 U8146-900
How do you access the belt on the WindTunnel V2 bagless? I have replaced the 4 rollers and I think the belt has broken, but can't figure how to get to it. Please help!
4 Suggested Answers
  • 294 Answers
SOURCE: I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Posted on Feb 28, 2009
  • 430 Answers
SOURCE: Hoover U8147-900 WindTunnel V2 Bagless Upright has
Most bagless uprights are exposed to dirt being drawn through their motors and filtered afterwards. As a result when you see sparks the motor has generally suffered its final breath... Today's uprights often run with high RPM disposable motors where older bag type uprights used lower speed rebuildable motors.
So the short answer is you likely need an entire motor as a minimum. If the unit is a higher end model mover $200 , in great condition and less than 5 years old, take it to a Hoover service center and either buy and install a motor or have them rebuild it. But also consider this...
What most people don't realize is they spend more on high priced consumable filters for many cheap bagless vacs than they ever would spend on bags and in the end the bagless is dirty to handle and has a shorter life span. Mass merchants sell the vacs cheap because their profit is in the filters
Remember a vacuum is the hardest working appliance in your home in the toughest possible conditions
If you replace this vac do so at a pro shop and see the options they have. You will get good advice , you will spend a bit more with better results and less frustration because you will build a relationship .....and always know where to go for service.
Posted on Oct 08, 2009
housejess
  • 317 Answers
SOURCE: The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Posted on Jan 03, 2010
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover Turbopower Wind Tunnel V2 - clogged - cannot find a way to get at the clog - HELP!
i took off the bottom black piece...removed the brushes ..took a coathanger and went down in silver dollar sized hole and got a big clog out...i also removed the black hose on the back at the very bottom...and used a coathanger up in there as well. mine is picking up some..but ive still gotta clog myself...i was hoping to find an answer here...-_-
Jan 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Mar 24, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site hoover.com
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Need to replace the brush belt for hoover u5750900
you havw 4 screws which hold the base plate on. remove these to expose the roller and belt. hook new belt on motor shaft (silver post) first and then put roller thru the belt. then stretch it to install into roller cavity. reinstall all screws.
Jan 02, 2009 | Hoover U5750-900 WindTunnel Bagless...
Replacing a hoover windtunnel vacuum belt U8147-900
This has no belts, there are 4 small brush rolls, if the ends are bad and not turning then you will need to replace them. The newer ones have metal instead of plastic so are better. Should be able to buy the brush rolls at a local shop or from http://vacuumsuperstore.com/U8120.html
Jun 11, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Vacuums Logo
73 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
