Question about E-Machines Computers & Internet
Usb ports still do not work, afterjust installing windows again. do i need to buy a new usb pci adapter card or is there a driver that can be located that is causing it not to work?
  • 60 Answers
Go to manufacturer website and go to support and find drivers for your model.
Posted on Oct 06, 2008
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
SIIG (JU-P50212) USB 2.0 Network Adapter
If you did a fresh install of Windows 7, make sure you install Windows 7 SP1.
A lot of Windows 7 drivers were not included in the original release.
The manufacturer does not list a specific driver for this card( although it does list it as being Windows 7 compatable) so likely you will find it by updating Windows 7.
Jan 05, 2012 | SIIG (JU-P50212) USB 2.0 Network Adapter
What adapter if any can be used for dell2400 to connect wireless
Most of the wireless adapters available now are compatible to all the computer system.
You can just buy a wireless adapter to any electronic/computer store and it should work after installing the software/driver that came in with the device.
Note when buying any device for your computer:
Always check for the Operating system compatibility of the device.
e.g. : if you have a windows XP system, make sure that the device is compatible with it.
Do the same if you have windows vista, 7 or any other operating system.
Aug 10, 2011 | Computers & Internet
Is Hi-speed USB 2.0 5-port PCI card compatible with Windows 7 and is there a driver available
According to belkins wweb site there is no Windows 7 driver or support for this card. From what I could find on else where it should just work with Windows 7. If you have the card installed and it is not being detected by Windows 7 I would remove the card with the system powered off. Turn it on so it "notices" that its no longer there, then power off and put the card back in, in another slot if you have one. turn it back on and it should detect it.
Mar 21, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Lost install instructions for Hi-speed usb 2.0 5-port PCI card.
The drivers are here. You shouldn't need to do anything to install the card other than plug it into a PCI slot in your computer and install the drivers.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
Pci card doesint work
What you want is a USB hub.  That will allow you to connect more than two USB devices to your computer.  There are two types, USB 2.0 and USB 1.1.  USB 1.1 will work for most slow speed devices, USB 2.0 is better for cameras and hard disks that have the support.  You should confirm which version of USB your computer has, but you should be OK getting a USB 4-port hub, plugging that into your computer, then plugging your keyboard and mouse into the hub and using the other port for the new peripheral that you wish to install.  Old PCI cards are problematic because you need the correct drivers.  You also need to make sure you plug them into the proper PCI port.  It sounds like the device you got from e-bay might be bad, so you shouldn't continue to use it.  If you post the make / model of your computer we might be able to suggest a new PCI card that will work if you still want to add more ports to your computer.
Apr 21, 2009 | VIA Vectro VT6212 (A62124) Serial Adapter
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
I need help installing my 2wire wireless adapter card.
I used this one:
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
PCI adapter did not install
I don't know how you could have installed the drivers BEFORE you installed the hardware... Shut down and UNPLUG the system; REMOVE the new PCI card, then hook up the power and boot the system back to the Desktop. Check the Device Manager to be sure you're not showing any problems; if everything seems back to normal, shut down and unplug the system a second time, then install the PCI card again, restore power, and prepare to reboot the system. Be SURE that ALL of the PCI cards are fully seated in the slots, and that the main power cable (from the PSU) is fully seated in the connector; IOW, check the system just to be sure that nothing has come loose while you've been working inside the case. Next, boot the system again; Windows SHOULD detect the new PCI card during bootup, though it might NOT request drivers, if they are already embedded within XP itself... Once you get back to the Desktop, open the Device Manager and check to be sure that the new card has been detected and properly installed. If you see any question marks, error messages, or exclamation marks, take detailed notes, and post that information here, so we can help you troubleshoot the problem... Good luck; I can only give you general advice about this, because you didn't provide any specific details about your new hardware, but with a little luck, you'll get everything working without any more heartburn...
Mar 31, 2007 | D-Link DU-520 - 5-Port USB 2.0 PCI Adapter...
Computers & Internet Logo
22 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
