Question about GE WBSR3140DW Top Load Washer
Drawstring tangled under agitator on an older GE washing machine.
How do I remove the agitator ?
  • 706 Answers
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Posted on Sep 21, 2008
  • Connie Williams Feb 12, 2014
    The hole tub wants to come out
How do I get a mattress cover stuck under agitator out?
On the older machines, the cap on top of the agitator unscrewed & then the agitator could then be raised.
Sep 13, 2014 | Washing Machines
Can't remove agitator on hotpoint washer
I have this same model of Hotpoint washer. I pulled up on the agitator and that separated it from the hub. I removed the hub by loosening the bolt at the top of the hub with a socket wrench. I removed the hub after removing the bolt. I removed the long stringy fabric by unwinding it and lifting up. that's all there is to it. Really simple. Everything went back together very easily. Only hard part is lifting the agitator up with enough force to free it from the hub.
Aug 10, 2012 | Hotpoint Washing Machines
How do I remove the agitator? The drawstring, with a metal tip, on a warm up jacket is caught under the agitator. I am afraid to cut the drawstring and have the metal tip get lodged in the motor.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the following illustrated description:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=91e06a88de852a10cb5618dcc88ab7e6
Basically, you'll remove the fabric softener dispenser, remove the top agitator (be carefull of the agitator dogs), remove the 1/2" drive bolt and the lower agitator should pull off.
Nov 23, 2010 | Washing Machines
How do i remove the agitator to remove a tangled drawstring
To remove the agitator you need to unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator if you want and replace the agitator cap.
Note: Damage to the snubbed, a pad like device sometimes located under the agitator cap, can cause the machine to vibrate excessively. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Kenmore Elite 45986 Front Load Washer
GE washer top load makes "chunking sound" in agitate cycle
unplug the machine- you should be able to turn the agitator by hand- turn it by hand- if you hear a noise, get a butter knife, or some other flat, thin item and move it around under the edge of the agitator, there may be a small object jammed under it! if so, then remove it, and enjoy the quiet! the agitators in many machines are removable- but you have to un-screw the top retainer, then use tool to loosen the agitator from the shaft- which can be a bit of a chore!! the older the machine, the more difficult! may want to check if your machine is level- but the spin cycle would tell you more! if it 'walks' across the room on spin, it's really out of level!!
good luck!
Oct 04, 2009 | GE WHSB8000B Top Load Washer
Need to remove agitator
IF THIS IS AN OLDER UNIT THE AGITATOR WILL BE SEIZED TO THE SHAFT ODDS OF GETTING THE AGITATOR OFF ARE VERY SLIM. IT SOUNDS LIKE THE NUT UNDER THE CAP IS SEIZED ALSO YOU SHOULD BE ABLE TO REMOVE THE CAP AND THEN USE WRENCHES TO REMOVE THE NUT
Aug 09, 2009 | GE WDSR2080D Top Load Washer
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
631 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
