Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
GE 5 Cycle Automatic Dryer Model DDE7207SBLWW
How do I get to the belt? The dryer started making this awful noice like a belt finally gave out. I need to do the repair myself for financial reasons so please explain how to get to the inside working area.
  • 1 more comment
  • DIYer69 Sep 29, 2008
    My dryer squeals very loudly when in use. The sound my go away for a few minutes or so occasionally. But it sounds awful and I can't take it anymore. I beleive my neighbors can hear the noise it's so loud.
  • Anonymous May 01, 2009
    Like giant hamsteres running on a squeaky exercise wheel! How do I fix it?
  • sl_deboard Sep 22, 2009
    my dryer drum is out of alignment...how do I re-align
  • 958 Answers
Hi peggins,
sorry we were not able to continue, if you have any more question, please use the ask me button.
drcool,
Posted on Sep 21, 2008
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE electric Dryer model GDX8060SW will not start, makes a humming noice only. Exhaust duct was clogged with lint, which I removed. Still only humming noice when trying to start Dryer. Is there a reset...
could have a jam still in the blower wheel and all...sounds like unit is getting power and trying to start if your getting a hmm but something is keeping it from turning...gain access to the blower area and check a little deeper for more obstruction...aso make sure belt did not come off of motor maybe motor is humming but not turning unit....
Jan 03, 2011 | Dryers
Dryer making rubbing noise like belt is weak, sprayed belt no change, tilled dryer forward noice stopped. ,also spayed with lubercate inside holes inside dryer noice stopped temporily
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 30, 2010 | Hotpoint NVL333GY Gas Dryer
Ge front load dryer wont start but all the lights work and you can pick a cycle it also makes clicking noise when you push start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | GE Dryers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
When I start dryer makes a loud hollowing noice and smells burnt.
hi dcimproveman,most common noise on whirlpool/kenmore dryers are the rollers.i would describe that noise as a klunk,klunk.klunk.what you do is unplug unit,pop the top,take off the frount,loose belt and remove drum.takes me less than 5 min.clean inspect/oil /no wd-40 replace worn parts as needed.if you get stuck,just send an email
Jan 01, 2009 | Kenmore 62602 Electric Dryer
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Opening a GE electric dryer
there are 2 screws directly under the main top. open the door and look up 2 phillips screws, this will release the top and from there 2 screws on inside lip of front panel will allow front to came off
Mar 18, 2008 | Dryers
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
1,358 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
