Question about Westinghouse WST2000 IntelliBLEND Work Top Blender
My grand daughter wanted to use a brand new HR2094 blender. Unfortunately she did not fit any part of the blade unit before loading the blender jar with the result that the yorkshire pudding mix oozed into the motor case and came out the bottom. Please where is the nearest Philips Approved workshop nearest my post code. Regards and Thanks Keith Hogan, Pond Cottage The Street Lidgate Suffolk, CB8 9PW
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Starbucks Glass jar replacement for blender
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
Leaking
Unfortunately Kitchenaid's design on those blenders is a one piece unit, over time the seals wear out and you have to replace the entire jar assembly, they usually run 40-50 dollars and can be found from several vendors.
Here is a link to the replacement jar on our site: KitchenAid Blade Jar Assembly W10555711
Nov 28, 2013 | KitchenAid KSB560MC 5Speed Blender
Replacement glass jar for 2003 Starbucks blender
Feb 02, 2013 | Braun MX2050 Blender Powermax Replacement...
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to customerservice@mendingshed.com
Sincerely,
Mendingshed.com Staff
Aug 28, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Westinghouse WST2000 IntelliBLEND Work Top Blender Logo
Top Westinghouse Blenders Experts
eyecam
ray gallant
Tom Chichester
Are you a Westinghouse Blender Expert? Answer questions, earn points and help others
