Question about Electrical Supplies
Coleman powermate PM0545305
Hi , first sorry for my not too good english !! I just start changing my coleman powermate's oil but i realize after changing it that there is no dipstick to check if there is enough oil in it to start (won't start if oil is low)... i just spent an hour checking it out but i can't start it anymore so there is too much or not enough oil in it but i don't know how many oil this thing can handle , i took some off, give some more but i didn't start...i don't have any manual.. instruction.. please give me a hand asap !!!
  • 1 more comment
  • karmina Sep 22, 2008
    is there anybody to help ? there is oil in the carburator , what do i do with this ?????
    ok i'll try the spray as soon as i can , but for the oil , there is no dip stick at all , so i don't know how much oil i'm supposed to put in it.... thanks very much for the advice , i'll get back to you about it
  • Anonymous Feb 09, 2009
    I want to change the oil on my proforce 3000watt 6.5hp ohv generator. What oil viscosity should I use?
    Problem Solver:
  • 13 Answers
You can check the oil on both sides. one side should have a dipstick. normally just fill it up all the way. you say oil is in the carb. spray some starter fluid in carb. and make sure air filter is clean. try to crank it and see if it will start. let me know if this took care of problem
Posted on Sep 22, 2008
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
I am looking for an owners manual for a Coleman Powermate generator model PMO645250
Powermate doesn't have an owners manual listed for the PM0645250 on their website.
Since wintertime is a good candidate for power failures I would recommend using a good synthetic 5w-30 oil as it is a good year around oil. This would make starting much easier during the cold weather
Oct 20, 2014 | Coleman Electrical Supplies
Older Coleman 3500 Watt generator, sitting for over 2 years. engine starts and runs normally, but no power generated.
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
Jan 05, 2010 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 wont start
Check your oil level and add a little if it's low. Don't overfill. Also, make sure the unit is level. You may want to change the spark plug. Depending on the hours you've used it or the length of time since you've used it may have taken a toll on the plug.
Beyond that, have a professional look at it.
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman powermate pm0545305 10hp brigg & stratton
go ahead and feel the oil resevior full . it will not hurt it. if you really want to find out if it is firing. if you are tough enough, put your finger on the spark plug and barely pull pull cord. you will definitely know if you are getting fire. it does kinda hurt though.....ouch!
if it is getting fire, then make sure gas is good. you may have to remove the carb bowl. the carb float may be sticking and the float pin. if this is the case, you may want to spray them with carb cleaner. if you know how to remove the carburator. you could soak the whole carb in carb cleaner. let me know how this works.
Sep 25, 2008 | Electrical Supplies
Electrical Supplies Logo
295 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
