Question about Brother SE-270D Computerized Sewing Machine
Problem with Babylock Esante BLN Embroidery Machine
I just started having a problem with my Babylock Esante. The thread started bunching up underneath the fabric and it keeps giving me a "Check upper thread..." error message. I've re-threaded it over and over with no change. I've also checked the needle to make sure it's installed correctly as well as changing to another needle. I've checked the bobbin to make sure it's threaded properly and even changed to a different spool of thread. I've also tried adjusting the upper tension. It does it in both embroidery mode and in regular stitch mode. I was looking at some of the other solutions, but didn't find one for my particular model. I understand that it's the same machine as a brother, but I don't know the which model. If it's a timing issue, how can I reset the timing so it's correct? Thanks.
  • Anonymous Dec 23, 2008
    I have the same problem. I will be taking it back to the sewing repair shop tomorrow since I bought an extended warranty and maintenance package with the machine.
  • Susan Kotarski Feb 04, 2014
    Are you placing the bobbin in correctly? the thread must flow "like a water fall" to your left. I also use only bobbin thread when embroidering. The correct stablizer is important to the type of material you are using as well. The needle should be at least an 11.
  • 1388 Answers
SOURCE: embroidery problems
You are speaking of two conflicting problems, when the bobbin thread shows, loosen the top tension, when it loops underneath, increase top tension.
It seems you are using different weights of thread for the different projects and this will require slightly differing tensions for each.
Are you sure you have threaded through all the guides, as the foam pad is only there to increase friction to prevent thread spool from rattling wildly (esp winding bobbin)
Take a look at this below to exclude the possible issues you face:
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just
take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really .....actually .....need adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
53ce8f6.jpg ...the other screw at one end is holding it all together, so is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
a780819.jpg FINISHING UP
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do is,
and eventually, you do get a "feel" for the correct tension and then it happens quite a user you won't be doing it very often unless there is lint built up (or are there
small hands at work around the house !?!?!)
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at
Posted on Feb 24, 2008
  • 185 Answers
SOURCE: babylock
The arms are serial numbered to match the machine. Each series esante is different.
If you can get me a serial number (off the back of the machine) I will tell you which series you need to order. I can get it through my work.
Posted on May 27, 2008
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: looking for a babylock esante manual. ESe2. The
I have a manual for the ESe2. If you still need it let me know
Posted on Feb 17, 2010
I have a babylock Esante Ese-2 and need a replacement embroidery arm.
You can try eBay or Craigslist for a donor machine. Or, contact your Babylock dealer.
Aug 17, 2015 | Sewing Machines
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Flashing Display, Won't Connect to Computer.
I have not yet seen babylock release a driver for windows 8 and the BLN. The dealer likely has a computer with an older operating system.
Jun 09, 2015 | Baby Lock Esante
Embroidery cards
try or a babylock dealer
Nov 12, 2012 | Sewing Machines
Babylock Esante BLN won't turn on. Wall plug
have you checked the power cord to make sure it's inserted correctly
into the machine?
if it is in the machine correctly, the problem could be the on -off switch
or the power cord
it would be a good idea to have the machine checked at a sewing machine
repair shop
Apr 28, 2012 | Baby Lock Sewing Machines
I inherited an Esante baby loc, golden anniversary limited edition. Unfortunately the manual was missing. I have searched everywhere with no luck. Any advice!
There is manual downloads from the Babylock website, I can't see this model but can see the Esante BLN, take a look, it may well be close enough to get you going. Otherwise you can contact BabyLock using their "Contact Us" page at the bottom of their home page,
Jan 05, 2012 | Baby Lock Esante
Looking for a babylock esante manual. ESe2. The
Nov 16, 2009 | Baby Lock Esante
Problem with my Babylock embroidery machine
I think you may have forgotten to put on the Q presser foot.
Feb 16, 2009 | Baby Lock Esante
Brother SE-270D Computerized Sewing Machine Logo
219 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
