Question about ASUS (M2NGREEN) Motherboard
NO DISPLAY M2NE MOTHERBOARD
My existing Configuration:
Monitor: BENQ FP71E+ LCD
Motherboard: ASUS M2N-E Green non sli (1 and half year old)
Display mode: DVI/VGA
Graphic Card: 7600GT
I was using above configuration for last one and half years. But one month back there was no display on booting the computer. It seems computer is booting up but I am not able to see any thing.
I have changed my graphic card to NEW 9600 GT but still no display. I have also tried different pair of RAMs 512*2 DDR2 but I am getting no display. My monitor is perfect, runs in DVI mode with another motherboard.
I have also done the barebone motherboard testing with another SMPS/RAM and CRT Monitor (vga mode) but still no display on the screen.
Any solutions..... Please help me out...
Posted on Dec 01, 2008
  • 22 Answers
It's probably your pci-e slot of the motherboard problem. Try using different motherboard.
Posted on Sep 21, 2008
Powers up ,but no bios beep or video ,displays error 50 on pc analyzer
Accordin to manual: Error Code – 50
Phoenix (50)Display CPU type and speed.(Beep)=2-2-1-1.(50)Per- form LSL instruction test.[Beep]=none Custom chip set or custom platform.
The POST process stop detecting CPU.
M2N-E SLI use Award/Phoenix BIOS.
Oct 19, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No display with ASUS M2N-E Motherboard
Repeat the procedures you learned , the exact same procedures apply to all situations
With certan motherboards you may still not see any video output
Which may mean an incompatability with the motherboard or defect
My advice is to plug in a CRT to the primary video port as a first step to getting video
Primary video port can also be the onboard video
Once you've got video you can begin the process of shutting down the onboard video and inserting
your new video card , with some motherboards if the person adds a new agp video card the system will automaticaly shut down the onboard video and use the new agp video card
BEFORE adding a new AGP video card
Don't forget to install ALL of your Microsoft Windows Critical Updates and Service Packs
because they will contain information and files that some computers require in order to function
properly with Nvidia Graphics Cards
That is especialy true of the FIC nforce2 motherboard.
You're in the zone.
Shalom >:D<
Sep 14, 2008 | Computers & Internet
No display with ASUS M2NE Motherboard
For getting display, you must have four components,
1. CPU (alongwith cooling fan)
2. Motherboard
3. RAM & of course
4. Power Supply (SMPS)
They must be connected properly and after attaching power supply unit you must ensure that a 24pin connector as well as a separate 4pin connector are connected to the Motherboard.
If the display doesn't come, the trouble may be with any of the four devices connected together. for advanced trouble shooting, please elaborate exactly when and how the problem has been generated. If the problem arised at the stage of initial assembly of the components, please check the components individually, if possible, replacing with another prouct of the same type.
If the problem arised on a running machine, please remove the RAMs from the slot, wipe the connectors of the RAM with a softe clean cloth and re-attach. If possible, you may wish to clean the RAM-slots on the board with a vacuum cleaner. In most cases, cleaning the RAMs do the needful.
Please try & reply.
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Half Display
That Seems to be a panel problem.Benq provides 3 year warranty,Try contacting local BenQ service centre in your country.
Samir
Aug 11, 2008 | BenQ FP71E 17" LCD Monitor
M2N- SLI Deluxe Motherboard won't power-up
Look for blown capacitors. Check this site for example pics.
Jun 29, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus motherboard M2N-E will not power up
It could be a memory card too. I would start by pulling the memory cards and see what happens.
Is there a connection on the motherboard for your hard drive?
Jun 12, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Am2 sli fault
does ur monitor light blinks if the monitor light blinks remove ur memory card and cleant the dust on the card and insert the memory card i think it will work
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS (M2NGREEN) Motherboard Logo
245 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
