Question about Bissell Vacuums
I smelled something like rubber abd now it won't pick up anything.
  • Fatimahtt Sep 21, 2008
    Thank you soo much :)
  • 706 Answers
In all probabilty, your beater bar brush was jammed and the belt that drives it was stuck while the motor that drives it was spinning. This problem will manifest otself as a burnt drive belt. If you can open up the base part ( where the beater bar is) and examine that area for the drive belt..chances are you wil find the problem.. while there.. make sure your beater bar is free to rotate ( power should be removed or disabled while checking all this) Hope this helps...
Posted on Sep 21, 2008
Brush doesn't turn all the time
The belt is worn out and you need to replace it. It's slipping and that's what you smell.
Nov 13, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
While 1/2 way through vacuuming my carpet, my Dyson 28 stopped picking anything up and started to smell like burnt rubber. I cleaned the roller on the bottom and spun it around to check the rubber belt. ...
I'm sorry to hear you're having difficulties with your DC28. Since you've checked for an obstruction, but have been unable to resolve the issue, it's probably best if you get in touch with us directly so we can provide the support you need as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My dirt devil ultra vision won't pick up anything and the brush does not turn, also smells like rubber is burning. What should I do? I checked to see if it was clogged and the belt is not broken.
Sounds to me like the belt has gone or at least stretched so it is slipping on the spindle, take the brush out and check for hair or anything wound round where the belt grips...don't know this particular vac but usually belts are not too difficult to change. Get a new belt from your hardware shop
Jul 11, 2011 | Vacuums
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum smells like burning rubber when on, no suction, leaving black marks on carpet
Usually when my vacuum smells like burning rubber, the belt needs to be changed and that is very easy to do. You just need to remove the the screws that hold in the rotator and put in a new belt. When the belt needs to be changed the vacuum will not pick up anything and this could make it seem like there is no suction. I hope this helps!
Nov 25, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
108 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
