Question about Motorola Mobility Z10 Smartphone
Ringtones 2nd time phone rings silent and wont play music all settings on am i thick does this phone have a mute button that i have pressed help help help
  • 1,952 Answers
The problem in memory card slot...remove and reinsert ur card pro in ur slot
Posted on Sep 21, 2008
The phone ringing is silent how to switch ringing sound on
There are many ways you can access your audio profile.
Normally press power button two to 3 second this will give you restart , shut down and audio profile option like general , vibration or mute.
Go to setting sound and notification and under that you will find ringtone setting.
Also under quick launch option you will find audio profile option.
May 02, 2017 | Cell Phones
My nokia c3 has no sound in music,or videos i is as though it is muted,whereas it's not muted.please give me the solution to this problem,cos this is the 2nd time it has gone silent.the 1st time it...
brother its a camera problem . go to hardware mech. and do check your c3 camera by reparing and if camera is ok then do the flashing of this mobile and your all problem will be solve ..
Nov 24, 2014 | Cell Phones
How do i mute incoming call on samsung s7220
Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
May 05, 2011 | Samsung Cell Phones
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Dear sirs. I hope you can help. I just got the droid HTC EVO. i somehow installed a music video that plays and displays whenever I get a phonecall with this terrible clip of some musician. I desperately...
here are two ways to setup a ringtone for incoming calls.
  1. From the Home screen tap Settings > Sound & display > Phone ringtone. Tap the ring tone you want to use on the list, and then tap OK.
  2. You can also use a music file as a ringtone. To set up a music file as your ringtone, please use the micro USB cable to connect the phone to a USB port on your computer. The Connect to PC dialog box displays and prompts you to choose Disk drive > Done. Your phone's SD card is mounted as a drive on your computer. You can now copy music files to the SD card.
After you have finished copying, open the notifications panel (by touching and then dragging the status bar down) on your device; then in the Notifications panel, touch Charge only.
Then tap All programs > Music > tap the music you want to set as a ringtone (the music will start playing) > press Menu > Set as ringtone. You can set the music file as a Phone ringtone or Contact ringtone or you can select Trim the ringtone.
Jan 16, 2011 | HTC EVO 4G Smartphone
Is there any way to mute the ring tone or put the ringtone on vibrate? While in meetings, etc. I want to leave my phone on but the ring silent. I can't seem to find how to do that on the lg xenon.
on the left side of the lg xenon you will see two buttons with two arrows pointing up and down press that and keep pressing it down or it will appear and you can touch and put it on silent
Aug 09, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Music and camera not working
It may be just on silent.
On the 580i there is a shortcut to muting and unmuting the phone.
When you first open your phone (standby screen) press and hold the # (pound) button for about 2 seconds. When your phone is muted, you will see a music notes symbol with a red line thru it at the top of the screen next to the antenna bars.
This may fix your ringtone problems but I don't know about the camera.
Nov 27, 2008 | Sony Ericsson w580i Cellular Phone
Phone stopped ringing
It seems yourphone has a silent mode.
It happened when you accidently press # button too long.
Try press the # button again!
Aug 18, 2007 | Samsung SGH-T519 Cellular Phone
Motorola Mobility Z10 Smartphone Logo
41 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
