Question about Tomtom GO 300 GPS Receiver
Battery will not hold charge
Tom tom will not hold charge
  • xray47 Sep 29, 2008
    I have a TomTom Go 930T, about 6 months old. The battery should give 4-5 hours but I get about 10 minutes
  • 3 Answers
Under warranty, have tomtom fix it, do not open it.
Posted on Oct 21, 2008
Tom tom troubleshooting
Your GPS will "freeze" (i.e. stop and shut down) if / when the battery level is low on the TomTom. If you have plugged it in a power source to charge it and the battery indicator shows that it is fully charged ... and then, when you unplug it from the power source, it freezes after a short period of time, it is likely that the battery will no longer hold a good charge.
If it does that while the TomTom is plugged into a power source, it indicates that the battery does not hold a charge anymore.
If this is the case, you may wish to get the battery changed (at an authorized TomTom service center, or do it yourself ... after getting the appropriate replacement battery and the tools/kit, and instructions). Just remember to follow the (initial) charging instructions (after you get a new battery) ... to ensure that the battery will hold a good charge for a long time.
Or junk it and get a new TomTom.
Aug 12, 2014 | Tomtom VIA 135 Automobile Portable GPS...
After pressing the on/off button nothing is happening,Ionly have the screen Tom Tom nothing else!
First, check that the battery is properly charged. To charge the battery, connect your device to the car charger. It can take up to 2 hours to fully charge the battery.
If this does not solve the problem, you can reset the device. To do this, press and hold the On/Off button for 15 seconds and release the button when your device begins to restart.
Hope this helps.
Feb 28, 2011 | Tomtom XXL 540TM Portable GPS
No charge on tom tom 1 sat nav. if i wiggle it it will charge but i cannot hold it all day
the battery is wekend you need to change it try buyng a new battery anf format it to hold more
Feb 24, 2011 | Sony Televison & Video
Tom Tom XL battery died and now placing onto computer to recharge and it doesn't seem to be responding - what should I do
Leave it on charge on the computer and if it does not still come on, then you try to fix it in another gps device and try to charge it on there, if it still does not hold a charge, then it means you will have to replace the battery, because the cells are weak and cannot hold a charge.
Jan 02, 2011 | Tomtom GO 910 GPS Receiver
My tom tom is over 2years. I am not getting a signal. Asks if I am in a building
Mainly the problem with this tom tom one is that it comes up with this problem frequently. The solution to this problem is for you to reset your tom tom by holding the reset button for a while, after doing that, it will reset it and it will be able to receive signals.
Solution: Reset the tom tom by holding down the reset button for a while, it will reset it and then it will be able to receive signals once again. To reset: check that your battery is properly charged, by plugging it for at least two hours, make sure the charging light is on. Then you press and hold the power on/off button for about 15 seconds, then it will restart the system for you.
Be sure to have your tom tom in a car or in a outside position where it can receive signals from the satellite.
This should do the job.
Dec 22, 2010 | Tomtom ONE GPS Receiver
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
My tom tom wont turn on where is the reset bitton
look for a small hole on the outside case near the sd card reader. might need a paperclip or pin to poke the microswitch inside the hole. simply clicking the switch doesn't work, try holding it for 5 seconds then try to power up. Common problem with GPS devices, (my mio included) is after being plugged in for a long time, the battery life becomes nil and it relies upon the charger. Check tom to xl for further problem solving. google search TOM TOM XL won't power up.
Mar 14, 2010 | Tomtom XL 340S Car GPS Receiver
My tom tom go920 wont hold a charge. from the car or cpu
Try recharging the battery in the car, and also at home with the USB cable.
If you see that it does not hold charge in both case, then you may conclude that the battery is defective. You should compare the TomTom claims with the actual result.
If battery is defective, you should be able tp replace it. Go to the TomTom onlibe store.
Jan 24, 2010 | Tomtom GO 920 GPS Receiver
Battery not holding charge
hi dave_hanc93
you say its not holding a charge, but is it charging?
plug the charger in and make sure the light is on on the charger, then on the map screen, tap the screen where the satellites are. on that screen on the top right is the charge indicator. is it green and moving from left to right? if not, then its not charging.
try hooking it up to the home dock to your computer and check and see if its charging on the home dock.
let me know how you make out.
bill
Oct 08, 2009 | Tomtom GO 910 GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
