Question about KitchenAid KGRA806PSS Gas Kitchen Range
Oven shut down
The oven shut down during self-cleaning cycle. The panel is off and the door is locked! Help! No display and door locked after using self clean feature - looks like a lot of other people having this problem. Not sure where fuse is to replace.
  • 2 more comments
  • wstirrett Sep 21, 2008
    Found the problem - was an open circuit on L110C Thermostat behind rear panel part #8300802 - jumpered it out and door unlocked an display came on
  • Anonymous Nov 23, 2008
    oven completely turned off during cleaning cycle
  • Anonymous Mar 08, 2009
    same thing here ... third time its happened... this is really bugging me
  • jojo62ramos Apr 08, 2009
    we have then same problem with this model. a technician came over and the diagnostic was the fuse also, he did not have the parts and needs to be ordered. you are right this model have this problem, kitchen aide should look into this issue...it is frustrating especially when easter holiday is just a few a days away.
  • 93 Answers
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Posted on Jun 10, 2009
How to use the self clean feature for a Frigidaire FES 355 ASF
Hi Anonymous, this is AP!
I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
Best of luck,
Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
My oven door will not shut all the way. It
It is probably the self-cleaning latch that keeps the door from being opened during the self-cleaning cycle. Looks like it didn't retract all the way. Did you use the self-cleaning cycle? . Do this: Quiet the house down, open the door slightly and close it, letting it hit the obstruction. Do this again and again. You don't have to close it hard at all; in fact, do it gently. By listening, you will be able to hone in what is keeping it opened. Then go from there.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Jul 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
KitchenAid KGRA806PSS Gas Kitchen Range Logo
466 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
