Question about Linksys Wireless-G WPS54G Print Server
Re-set of wireless g print server
When i plugged the wireless g printer server into my new printer it stopped working. a hard reset didn't work either
  • Linksys Master
  • 6,487 Answers
With this print server not all printer are compatible with it, but if you connect same model of printer that was also working with this print server, best thing to do here again is to reset the router and reconfigure it back using the setup CD that came with it and if still the same problem, it will be better to call Linksys tech support so they can check if your printer is compatible with this print server if its compatible let one of the Linksys tech walk you through with the process, they are open 24/7 this is the number 800-3267114....
Hope that helps...........
Posted on Sep 21, 2008
I cannot work out how to connect my printer with my d-link DIR-655 router. When I take the printer USB out of my computer and plug it in to the USB port on the router, I cannot print from mycomputer. I...
You cannot set the printer up directly on the router as the router needs to have a driver to understand how to use the printer. If you have a wireless printer, you need to enter a wireless key on the printer, you'll have to do that from the printer interface (you didn't list your printer model so i'm not sure how exactly you do that). On my wireless printer there is a nice network setup menu on the touch screen display.
Then you have to install the full drivers for the printer and tell it the printer is connected wirelessly and it looks for it and finds its IP address and allows you to connect to it.
If you do not have a wireless printer, and need to print wirelessly, you will need to buy a print server.
Apr 17, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Print server was working fine. All of a sudden, lost signal, tried to re-install with no success. Says: Can't find printer or wireless network
Mostly these servers run and than stop for ever by hardware failure (overheat) If you have warranty use it after trying a hard reset.
Jan 12, 2011 | HP 2101nw Wireless G Print Server...
Wireless print server WPS54G stopped working.
I would try running the setup on it again, and if no luck setting up again, then yes it is toast.
Jan 01, 2010 | Linksys Wireless-G WPS54G Print Server
Problems with my print server. Just stopped working yesterday day out of the blew. No getting following error: Network host '192.168.1.2' is busy; will retry in 15 seconds...
first see if that ip address is taken by any other device... than the one who is sopposed to have it... if it is not then you need to reset you your linksys by plugging out the power and plugging it back in... if that doesn't work then you need to do a hard reset with the reset button...
Dec 26, 2009 | Linksys Wireless-G WPS54G Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Problem setting printer server
Please follow this document step by step to get it working
http://downloads.linksysbycisco.com/downloads/WPS54G_qi.pdf
let me know what step you get stuck at.
Apr 05, 2009 | Linksys Wireless-G WPS54G Print Server
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Print server thinks printer is offline
This printer works only with selected printer and they do not work with other print sever to know the print server which they work please click on this link and then click
Hide/Show Additional Results
http://search.lexmark.com/printer/US/en/22N5000
This server will cost $149 instead you can buy wireless Lexmark printer X6570 at the same price,
Good luck..................
Jun 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Prints part of the page then restarts the print
One suggestions would be to update the firmware of the Netgear Wireless print server Download the firmware for your print server from Netgear's website http://kbserver.netgear.com/release_notes/d102781.asp Instructions for upgrade are on the site! you can also try changing the spool settings, Set it to Print directly to printer RightClick on the printer click on properties and click the advanced tab. Change the spool setting to print directly to printer!! If this doesn't work kindly let me know! regards, babb
May 11, 2007 | NetGear WIRELESS PRINT SERVER 54MBPS...
Linksys Wireless-G WPS54G Print Server Logo
385 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
