Question about Pioneer PRO-620HD 58" Rear Projection Television
I have a pioneer pro 620 hd wont turn on
I think its one of the fuse but i see there more then one so which one do i replace ....the red light is on but it wont turn on even after i unplug it please help
  • Anonymous May 09, 2009
    Unit has standby red light. Unit will not come on has no high voltage. Belive that the deflection board is bad. If you have any componet leavel solutions to fix please let me know. I am a service technican trying to find some info on this set .
    Thanks,
    Dustin
  • azzacab
    azzacab Jan 06, 2012
    Dustin sounds like a very smart guy , like the right guy to know in these situations. I would love to get to know someone like that , to turn to for questions or even good conversation. Be well, real man of genius.
I have been dealing with the same problem with the identical set. I'm pretty handy so rather than junk the set, I took off the rear panel and stuck a small fan in the back to cool down the inside of the cabinet. I love the picture on this TV so I'm doing all I can to save it. Sometimes it doesn't turn on so I have now taken off the front panel (speaker cover) and also the front access panel. I carefully reach inside and have to wrap on the part (with a long wooden spoon) that I hear clicking from when I hit the power button. I used to just give the cabinet a swift kick and it usually would turn on, sometimes after several kicks. Kick it, then hit the power button. So whatever the problem(s), it's not keeping me from watching a gerat picture. I have a feeling that if I took my air compressor and blew out all of the dust from all over the components, it'd probably solve the problem of it shutting itself off after an hour or so. Why it doesn't always turn on is anyone's guess, but a good tap or two with my wooden spoon here and there and it turns on eventually.
If you've already got rid of the set, I understand. I almost did the same.
Posted on Dec 25, 2008
Pioneer Elite Pro-1139 HD Tv has no picture but has audio. Red standby light is blinking 10 times then pauses.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 16, 2015 | Pioneer Televison & Video
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a pioneer pro 730hd took the back off and now the red power light just blinks and it wont turn on
If convergence was off it may have railed (shorted convergence chip) and the set is now in shutdown.
Also go over inside in case you moved or pulled a plug loose.
This is not an easy set to replace the chips and only the original remote will adjust convergence.
Mar 17, 2012 | Pioneer PRO-730HD 64" Rear Projection...
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
Oct 16, 2009 | Televison & Video
Red blinking light
same problem, red blinking light in series of 5 flashes
May 30, 2009 | Pioneer PureVision Pro-1000HD 50 in....
Wont turn on
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Mar 29, 2009 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Wont turn on red light flashes
Hope this hleps
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer plasma no picture with blinking red light
this requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
Oct 28, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PRO-620HD 58" Rear Projection Television Logo
259 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
