Question about Neff Microwave Ovens
I can't work out how to fit a new oven light bulb
  • 706 Answers
Please provide brand and model number so that I can assist you with this...
Posted on Sep 21, 2008
How do I fit a new light bulb in my Jt355 microwave
Pull the bulb, & the model bulb replacement should be stamped on the metal base of the bulb...you may need a magnifying glass to see it.
Feb 28, 2015 | In Microwave Ovens
Pull the light bulb out & match it...should have a model number on the base etched or tagged.
Feb 28, 2015 | Microwave Ovens
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
Microwave oven work light doesn't work
Then you have bad light socket or some broken wire to this socket.
Nov 30, 2008 | Microwave Ovens
GE Spacemaker Model No. JVM1650AB 003
Hello Diana,
Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
Good Luck !
Sep 14, 2008 | Microwave Ovens
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Work & Night light on Sharp R-1611 won't work.
first check if light bulbs is ok these bulb are connected in series if one is fused both wont work 'first if u look at the two fiitings you would find a common wire disconnect from both .now you are left with two wires one connected to each fitting .disconnect from one fiting and conect to the other .now u will have one fitting connected and one totally disconnected .try bulb ifit works disconnect that fitting and try the other one .by elumination you will find out if the fitting is faulty
Jul 31, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
