I can't connect to the internet with my desktop. I have a linksystem cable modem connected to it. I tried using the ethernet cable to no success.I also tried using a usb port to no success. and I tried wireless and still no success. can someone please give me some help with this problem.
  • 781 Answers
How many lights does your modem have and how many do you see lighting? if you have only 2 lighting..you may want to contact your internet service provider and get them to reset your connection.
try using your ethernet cable... when you plug your cable to the back of your computer and to the modem... do you see lights blinking at both ends when both devices are on.. if not.. try replacing the cable for a known good cable. make sure all your cable as properly secured.
check if your internet connection settings are ready to receive an ip addres:
go to start>control pannel>network connections.. hight light local network connection (your network adapter) and right click and select properties... then in the general tab scroll down untill you see Internet protocol (TCP/IP) click on it and the click on the properties botton. in the general tab of properties.. make sure you have selected "Obtain an IP address Automatically" and down below "Obtain DNS server address automatically"
if everthing looks ok.. try to repair you connection by going to start>control pannel>network connections.. hight light local network connection (your network adapter) and right click and select enable (if disabled) or repair.
Posted on Sep 21, 2008
My internet doesn't work
Plug a different computer into your cable-modem or DSL-modem, to see if that computer can successfully use the modem to access the Internet.
Try a different Ethernet-cable between your modem and your computer, to see if that fixes anything.
Click Start
Click Control Panel
Click Network Connections
Under the "Local Area Connection" icon, do you see "network cable unplugged", or "disabled" ?
If so, connect the cable, or right-mouse-click on the icon, and choose "enable".
Dec 07, 2010 | E-Machines eMachines Desktop PC
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
I have a linksystem router and its says the network is set up but when i try to connect to the network on my laptop it will not connect to the internet but the computer tells me its connected with...
Make sure that the ethernet cable (looks like a big phone cable) that is coming from your modem (usually a small black box that your cable company gave you) is plugged into the Internet port on the router. You can verify that it has a good connection if the Internet light is lit. Also you should find a LAN or PC light on your modem that will also light up.
Jan 24, 2010 | Linksys Wireless-G WRT54G Router
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Two Questions Connecting with Belkin Wireless Router...
To answer the first question, please provide what kind of operating system you are using, and please provide the exact error message. Its probably just a caution/nag that you don't really have to worry about, but if you provide more information then so can we.
For the second question, you will need to setup the WEP on the laptop to get the laptop to connect to the router via wireless, regardless if it was used to setup the router, the wireless network is encrypted so it will need to be accessed by a computer(s) that have the key programmed into them. You can plug in the laptop into the hardwire Ethernet port for configuration, that is another option.
May 14, 2008 | Belkin (F5D7231-4) Wireless Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
