Question about Mitsubishi HS-U510 VHS VCR
Mitsubishi hs510 I just received an old Mitsubishi hs U-510 VCR that was working but when I plug it in and push the power button there is no response. Nothing lights up but when I unplug and plug it back in I can hear a sound as if it were going to power up, however - nothing happens when the power button is pushed on the VCR or the remote. Also, I put a tape in the unit and now it will not eject. Please help. Dee
2 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
Mitsubishi hs-u62 vcr cassette will not eject
Needz fresh belts. You can order common o-ringz uv the same length that will work fine, but usually not az long.
Apr 19, 2015 | Mitsubishi Televison & Video
Pinch Roller replacement on Mitsubishi Model HSU550
Another roller type thing, attached to baseplate, squeezes the tape against that roller to drive/guide it.
Jan 27, 2010 | Mitsubishi HS-U530 VHS VCR
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
Need a substitute remote for mitsubishi hs-u431
If you go to www.remotes.com you can order an original replacement for your unit!
Please rate my response
Thank
You!
Jan 11, 2009 | Mitsubishi HS-U431 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
I contacted Mitsubishi support. It is very likely the 510 and the 520 are similar. I was told to look at the back of the VCR (in the middle and lower) for a "timer reset" button. Pushing it will put you into initial setup mode and you can set your VCR to english menu. It works!
Ronrr
Jul 14, 2008 | Televison & Video
Play button does not work
Check the little drive pulley underneath the mech. It is very common for this to crack or break and not drive the takeup reel.
Nov 29, 2007 | Mitsubishi HS-U760 S-VHS VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Mitsubishi HS-U445
Check batteries in remote- maybe they are weak/dead. Do the buttons on VCR itself do anything? Unplug VCR for a few minutes, perhaps this will clear the condition. Mitsubishi doesn't show your model, but perhaps this one will be close enough: http://www.mitsubishi-tv.com/j/i/18326/HSU449.html?cid=42
Sep 13, 2007 | Mitsubishi HS-U446 VCR
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
